turbo on an N/A 2.3?
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 9th, 2011, 03:44 PM   #1
1990 Mustang LX 2.5/auto
18s?(wild guess)
ZebLX90 is on a distinguished road
i know the turbo 2.3's had forged rods and pistons instead of cast iron and i know that the combustion chambers in the head were more of a "D" shape and that the turbo motors have an oil drain in the block for the turbo
but my question is when i bought my car the motor was blown so i rebuilt it using forged internals,
so if i get
-turbo 2.3 head
-8UA ecu (cause its auto)
-turbo coupe wiring harness
-larger VAM
-brown top injectors
-turbo,intercooler,wastegate,etc
-fab the oil pan
-Mass air meter
could I then SAFELY turbo my N/A 2.3? has to be built to last its my daily driver
sorry about the length and any info would be GREATLY appriciated
thank you
Old October 9th, 2011, 09:47 PM   #2
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
Yes, and the N/A 2/3s have forged rods, cast aluminum pistons, and bothe the 2.3t and 2.3 use cast iron cranks. The pistons and proper engine management are crucial though.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old October 9th, 2011, 09:53 PM   #3
18s?(wild guess)
actually the motor is a 2.5 out of a later model ranger and it has the according crank with forged steel rods and pistons
and by engine management i assume your talkin about using the correct ecm,injectors,fuel pump,etc right?
Old October 10th, 2011, 10:52 PM   #4
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Zeb, you can turbo the stock motor as long as you tune it properly and keep boost at a conservative level. You don't need a turbo head and may find it difficult to locate one. Is your current motor a dual plug engine or did your keep the single plug head?
I'm not totally clear on what pistons are in your rebuilt motor, you indicated that they were forged, are they dished or of a flat top design?
The engine management system from an 87 or later T-bird would be the preferred system, but not an absolute requirement and you might find it to be more expensive in the long run to use that system, rather than sourcing parts from other turbo 2.3 Fords and using a custom tuner to perform a final tune.
Your stock fuel pump will be on the weak side for this application, so I would suggest that you replace that first with a 190 LPH pump, a dirty job, but needed.
Supercharged 2.7L
398 HP
501 ft lb !!
Old October 11th, 2011, 07:09 PM   #5
18s?(wild guess)
I kept the single plug head and just curious what is a "conservative" level of boost?
as for the pistons there flat top pistons,also they might not be the right ones im 100% as i bought an assembled shortblock locally and was "told" they were forged
if I couldnt get and 87+ turbo coupe what would be a good second choice and also who makes a good custom tuner?
thank you for the reply all info is greatly appriciated
Old October 11th, 2011, 10:34 PM   #6
OHC230's Avatar
11.945 @ 119.6
OK, I am going on the assumption that you are running flat top pistons, hopefully forged and you have a 89-90 N/A head, which out of all of the iron heads, I like the most. Your compression will be anywhere between 9.0:-9.8:1 if you are using a standard head gasket and a non milled head. I would start with the boost at 10 PSI and see how that goes first.
If you are JY shopping for fuel system parts, then be on the look out for any turbo ford with brown top injectors.
Here is your link to one of the more popular tuners for the 2.3.
Moates.Net
Supercharged 2.7L
398 HP
501 ft lb !!
Threads Similar to: turbo on an N/A 2.3?
Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi Turblow 99-04 18 November 9th, 2010 09:12 PM
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT General Tech 14 July 11th, 2008 07:01 AM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 04:15 PM
