BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
May have found a Rolling Chassis, need advice on 2.3T swap.
Hey guys. I think lucked out and found a rust free, 5.0 rolling chassis. Waiting on a bit more info, but I can get it for $1500, maybe $1000. It doesn't have Trans or Motor but has everything else. It was a 1991 5.0. Has a bunch of aftermarket suspension goodies so I'm pretty excited. My questions are: what to look for in a used turbocoupe motor or SVO motor? What should I replace even before dropping it in? How much should I look to spend on a good running motor? Which ECU/harness should I get? I would like to tune on Quarterhorse as I have a bit of experience with it already. I also already have a brand new NGK Wideband with a NTK sensor. How much should I look to spend on a harness? I'll be deleting A/C and the heater core as this will be a autocross/road coarse build. I'm also looking for a SN95 Cobra trans, rear end and spindles. Will I need anything to adapt the trans to the 2.3? What k-member is compatible or should I use? What motor mounts?
I know it is a lot of questions so I'm not expecting quick and easy answer's. I've done a bit of research and it seems there is a lot of turbocoupe/SVO motors out there for $500 but that seems almost too good to be true? Thanks a bunch fella's! Jake |
1988 2.3L Hatch
Ha-Ha
You cant use the SN95 trans because the Input shaft is too long.
They make an adapter plate that bolts to the 2.3 block and uses the 5.0 bellhousing pattern. this will allow you to use anything that bolts up to the old 5.0, and you can buy a larger diameter flywheel to use the 5.0 clutch and starter.
STINGER PERFORMANCE PARTS - 2.3 Turbo Performance Parts for Mustang SVO, Thunderbird Turbo Coupe, Merkur XR4Ti, Pinto, Ranger, and Sand Rails all the components are located here^
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
#4 | |
BWAL Is My Hero
Thanks for the heads up. What is the best option? I plan on making about 300HP and as close to 300FT/LB's of torque as I can get. I won't do auto.
BWAL Is My Hero
Also, is Megasquirt a better idea? Or maybe even Stinger's "Pimp" Stand alone? Not really looking to spend $650, but if that is the best I could plan on adding that in the future. I'm not afraid of installing a stand alone as long as it is more ideal. Even with quarter horse it would still be speed density right? I'd rather use speed density so I don't have to run a MAF sensor or Alpha-N.
BWAL Is My Hero
I found it for sure! Guy sent me Pic's today. Going to go look at it this weekend! Thing is damn near mint and I wasn't even really looking for a mint car...
1988 2.3L Hatch
Ha-Ha
I am running an 88 GT t5 with the 4 cyl bellhousing and 4.10 gears and a stock TC clutch.
Proud American
Big stuff 3
![]() Or a carb like the cool cats
Priest of the Car Gods
You know, another option is to look outside Ford. If you're looking at a 2.3T, you might also consider an SR20DET. I'm not a Nissan fan, but the SR is just one of the best 4-cylinder performance motors out there, and IIRC Nissan even used a version of the T5 behind it.
Too bad the Ecoboost 3.5L hasn't been out long enough to get one cheap and there's no RWD manual trannies for 'em (that I'm aware of)... I think an Ecoboost foxbody could be a scary, scary car.
#11 | |
I thought the EcoBoost F150 was only offered with an automatic.
#13 | |
BWAL Is My Hero
Being that they have a PnP eec-iv setup I think I will.. I think it will cut out a bunch of hurdles. Easier to datalog as well.
No carb's for me.. Silly black magic... We use BS3 on our dragster, but I don't have the budget that my uncle does. LoL If I could, I would. I LOVE BS3... I mean seriously.
I can get a Turbocoupe motor for between $500-$800, long block with the turbo and all. If I get this chassis I think I could do it for under $3000. Which would be PERFECT. Then after I get a season out of it I could do all the suspension and motor. This chassis has full suspension short of a T/A PHB setup. |
BWAL Is My Hero
No adapter's or anything? Wouldn't that be a T45?
BWAL Is My Hero
Still need advice on sourcing wiring harness (assuming I use megasquirt eec-iv PnP), what transmission to use (has to be manual) and what fuel pump to use? Anyone have experience with the aeromotive 340 stealth fuel pump? Link here. Should I just do a 255 walbro and call it a day? Fairly certain I'm going to get the stock Mustang GT Fuel pump and all the lines with the chassis. The tank and all that for sure. I know i want to remove the heater core and all that stuff, what do I need to block off or modify on the SVO/TC motor?
Blah.. LoL The farther I get into this the more questions I have. I've been searching the net, but I haven't gotten a lot of clear answers. |
The T45 was only used in 96 to 99
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. Last edited by Mikel89us; October 20th, 2011 at 10:37 PM. |
BWAL Is My Hero
Huh. Learn something new every day. Ty.
1988 2.3L Hatch
Ha-Ha
Longer than that, 96 to mid '01; that's when they switched over to the 3650. And the T5 was still in use then behind the V6s - the last of the T5s are in the 2010 4.0L cars.
#20 | |
They say that in 2000 tremec replaced it with the TR-3650. That doesnt mean tthat ford didnt have spares laying around, but the T45 production was stopped in 99
Threads Similar to: May have found a Rolling Chassis, need advice on 2.3T swap.
| 98 cobra rolling chassis | 98Cobra_sleeper | Vehicles For Sale | 4 | October 11th, 2011 12:39 AM |
| Rolling Chassis Questions | jfritts | Classic Mustangs | 1 | November 2nd, 2009 08:10 AM |
| Just got a free Rolling Chassis 1980 Camaro! | svtkidd23 | The Clubhouse | 55 | September 1st, 2009 04:16 PM |
| Any One Have A Rolling Chassis In NJ Area | 92lxhatch | 5.0 Mustangs | 2 | October 8th, 2006 02:14 PM |
