pilot bearing
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 25th, 2011, 11:57 AM   #1
thedriver33 is on a distinguished road
pilot bearing
how does one go about getting this dang thing out of the crank.....
after 2 days of F ing with it i took a dremel to it in hopes of getting outter shell casing out of the crank.....the roller race was gone already when i pulled the tranny.
but comparing it to the one on my old v6 and 5.0 there is nothing for a puller or slide hammer setup that can grab on to it.
anyone have this problem?
-87 5.0 notch (slowly being built.....)
-92 5.0 Hatch (getting ready to be DD)
-93 2.3 notch (DD)
-(sold) 96 3.8 coupe
-(sold) 82 5.0 hatch
-(sold) 85 2.3 Coupe
-(sold) 91 5.0 Coupe
-(sold) 91 Hatch 5.0
Old October 25th, 2011, 10:27 PM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
You see this all the time, if you are a mechanic by trade. Several companies make pullers for pilot bearings and they work with varying degrees of success. A lot of auto parts stores rent them. For stubborn bearings, it sometimes necessary to carefully grind a shallow groove into the outer bearing housing, after which you can split the housing, using a small chisel to collapse the shell inward. No need to grind all the way through, you just need to weaken the shell. (see pic of groove)
OHC.
Supercharged 2.7L
398 HP
501 ft lb !!
Old October 26th, 2011, 06:16 PM   #3
lol, tried to grind it, thing wouldnt collapse not matter what i did to it....its the orignal once from the factory.....ended up just grinding the whole shell out...pounded the new one, grease the crap out of it, put trans back in....couldnt wait any long need to the car drive the next day.....been 4 days no issues....over 400 miles...
-93 2.3 notch (DD)
Threads Similar to: pilot bearing
Pilot Bearing.... MATT02GT 99-04 39 July 12th, 2010 03:37 AM
is this pilot bearing ok? PolishSasquatch 5.0 Mustangs 1 July 30th, 2009 11:31 PM
pilot bearing refuses to come out PolishSasquatch 5.0 Mustangs 3 July 30th, 2009 09:26 PM
Pilot Bearing??? batlaxe 5.0 Mustangs 8 May 17th, 2009 06:52 PM
i cant get my pilot bearing out B0B The Clubhouse 6 April 18th, 2008 07:50 PM
