quarterhorse rev limiter
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 28th, 2011, 01:12 PM   #1
a couple 2.3's
DJ2.3 is on a distinguished road
To those of you who have a quarterhorse on their C1A1 or D1L1: Are you able to raise the rev limiter with the CRY def file from eecanalyzer? There is some discussion about this on some tuning forums, but i haven't been able to get a definate answer. I am trying to raise the limiter on my 2.3 ranger and was considering using the d1l1 eec if i can confirm that the limiter can be raised. If not i may have to use a 5.0 eec but thats looks somewhat complex.
Old November 1st, 2011, 08:38 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
You can raise the RPM limit by changing pip signal scalars to a higher value.
Supercharged 2.7L
398 HP
501 ft lb !!
Old November 1st, 2011, 01:32 PM   #3
a couple 2.3's
Is this confirmed? Some guys on eectuning were having trouble raising the limiter. What eec are you using OHC?
Old November 4th, 2011, 10:28 AM   #4
OHC230's Avatar
11.945 @ 119.6
"What eec are you using OHC?"
I recently switched over to an LA3 and a 70MM MAF. I was using an early MAP ECU before.
Supercharged 2.7L
398 HP
501 ft lb !!
Old November 9th, 2011, 01:51 PM   #5
a couple 2.3's
I went ahead and got the C1A1 / D1L1 strategy and tried it. The rev limit is exposed and can be raised. I have the d1l1 in my 92 ranger and it is working fine-no CEL anymore! I had to turn off bp sensor, auto trans, and eletric fan, and change the maf transer. Seems to be working great so far.
Threads Similar to: quarterhorse rev limiter
Quarterhorse trouble Cgross609 2.3 Mustangs 7 May 26th, 2011 08:54 AM
quarterhorse is in EscortSportage 5.0 Mustangs 1 February 26th, 2011 08:40 PM
Anyone running quarterhorse? 88Saleen 5.0 Mustangs 4 January 3rd, 2011 11:52 AM
moates quarterhorse 88Saleen 5.0 Mustangs 22 October 14th, 2010 04:52 PM
Moates Quarterhorse that5.0girl 94-95 14 November 3rd, 2009 12:59 PM
