New 2.3T Wont Start Or Crank
I just got my 2.3 turbo motor into my 91 LX and it wont start at all. I turn the key and nothing happens. I put a new starter on that I just had tested and checked out. I shorted the solenoid and it clicks. The battery has juice. What could the problem be?
1988 2.3L Hatch
Ha-Ha
Do the dash lights come on? It sounds like an ignition switch issue.
Supercharged 89'/ 85' SVO
11.945 @ 119.6
Brandy, can you turn the motor over by hand using a breaker bar?
Check your cable connections. Take them apart and look at them (with battery disconnected) use a wire brush to remove all corrosion. Is battery fully charged?
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
the dash lights do come on. CAbles are clean and yes the engine can be rotated by hand. I got it to rotate yesterday by using a screwdriver on the starter solenoid but sometimes that works and other times it doesnt.
unstoppable @ speed of light
Does anything come on when the key is put to the "run" position or "acc" position?
Double check the grounding strap has good contact on BOTH ends. I fought a poor connection with the block ground strap for days before I realized what it was. A cheap/very easy way to check, get some speaker wire, wrap it around a header tube and put the other end on the fire wall in an area with NO paint. Have someone crank or do it yourself.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
Try the ignition wire it may have came unhooked from the solonoid
Threads Similar to: New 2.3T Wont Start Or Crank
| car wont start OBD II wont read. ECU? | ForestGRN_Ghost | 99-04 | 7 | September 14th, 2011 11:38 AM |
| Plugs out, crank still wont turn | RickyBobbyFL | 99-04 | 10 | November 10th, 2010 01:25 AM |
| Crank but no start | 817B!GT3X | 5.0 Mustangs | 12 | September 18th, 2008 07:59 AM |
| Car Wont Crank From Ignition | JcSurge311 | 5.0 Mustangs | 2 | December 17th, 2007 08:10 AM |
