1987,mustang,lx
where can i get a turbo
hi i have a 1987 4 cyl no turbo mustang coup but want a turbo for it were can i get a turbo kit with every thing i need dont know what i need never had a turbo car before help
If you want a tro kit with everything, youre out of luck. But if you want to do a turbo coupe/ svo swap you can pull an entire engine, harness and ecu out of another car. If not you can talk to some of the guys on here and they can get you a list of all the parts you will need.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
I would use the whole turbo coupe engine, arent the internals on it forged? I hear a tcoupe turbo will shatter pistons in a normal 2.3
All 2.3s have a cast crank, they all have forged rods. The N/A engines have cast pistons, and the turbo engines have forged. You can boost an n/a bottom end, but it will not likely last very long.
unstoppable @ speed of light
The head design is the largest drawback for putting a turbo on a n/a 2.3 car. It's just not boost friendly. It would be cheaper and safer to find a junk yard 2.3T car and pull all of the engine, ECU and harness out of it. Most 2.3T engines can be had for a couple hundred ish, the ECU and harness if it's not still in the vehicle can be found on 2.3T specific forums for a couple hundred at most normally.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
Supercharged 89'/ 85' SVO
11.945 @ 119.6
I'm going to respectfully disagree with 03R Code on the head. I've done quite a bit of analysis on 2.3 heads, both statistical and empirical and I really belive that the 85-90 castings are likely the best iron heads out there. Flame propagation is fairly efficient in the N/A heads, which is surprising considering the age of their design. besides, if you don't prefer the chamber design, they can always be re-machined. ![]()
![]() Supercharged 2.7L 398 HP 501 ft lb !! Last edited by OHC230; November 15th, 2011 at 09:15 PM. |
Threads Similar to: where can i get a turbo
| Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi | Turblow | 99-04 | 18 | November 9th, 2010 09:12 PM |
| Turbo timers and Boost Controllers? Turbo guys where you at? | 95StangSVT | General Tech | 14 | July 11th, 2008 07:01 AM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
