2.3 troubles
Tachometer goes no lower then 3k. Seems to pulse when airbag light blinks.
no power. Pulled codes KOEO 334 512 KOER 998 224 Also i noticed the MAP sensor has no vacuum line on it. Shouldnt it? |
Supercharged 89'/ 85' SVO
11.945 @ 119.6
What year is your car?
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
oh sorry its a 1992. pure stock. 5 speed
11.945 @ 119.6
These are the 2 codes that you have to address.
224 PCM detected coil 1,2,3 or 4 primary circuit failure 998 Hard fault present Try checking both coils for spark. If you have an old spark plug, it makes this easier, just pull a wire from the inside bank, stick the plug in and start up the engine, then test the outside bank of cylinders and let us know what you get.
test each plug? or 1 from each coil? Could this be my module?
11.945 @ 119.6
Both the module and coils are prone to failure, so it's possible. Just test one plug on each coil,
Threads Similar to: 2.3 troubles
| Pro-kit Troubles? | yeahyouknwit | 99-04 | 0 | December 14th, 2010 11:12 AM |
| Ahhh troubles, troubles. | 02trueblueGT | 99-04 | 1 | August 20th, 2010 06:49 PM |
| having some troubles | roosgt! | 99-04 | 2 | August 12th, 2010 12:20 AM |
| having some troubles | 94_peice_together_STANG | 5.0 Mustangs | 1 | August 3rd, 2010 11:27 PM |
| VT Troubles | limited | 99-04 | 33 | November 21st, 2007 07:39 PM |
