Battery meter at zero, changed battery and still nothing
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old November 15th, 2011, 03:13 PM   #1
Former4banger's Avatar
1992 2.3l lx hatch
Former4banger is on a distinguished road
Thumbs down
So I was driving home and noticed the volt meter really low. After a few minutes it was in the red, my stereo turned off and lights were dimming. I made it home and I just assumed my battery was toast. Sodthis morning I went and bought a new one put it in and it wont start now. It seems like the battery is dead. I put jumper cables on it and still wont turn over. Could it be my alternator?
Old November 15th, 2011, 04:49 PM   #2
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
Id say it is your alternator, seeing as the voltage meter continued to drop. Take it off and get it tested. But if you jumped the battery, it should still turn over with a bad alternator
Old November 15th, 2011, 05:22 PM   #3
1992 2.3l lx hatch
Im going to see if I can get off work tomorrow and get it tested. I can take it to my local auto parts store and test it right? If its not my alternator, any thoughts on what it might be. I forgot to mention that its a 1992 2.3 lx. Yeah I jumped it but still wont turn over. Just cranks and sounds like the battery is drained
Old November 15th, 2011, 05:25 PM   #4
Jackal13 is on a distinguished road
Check your positive cable from battery to solenoid.
Old November 16th, 2011, 12:52 AM   #5
1992 2.3l lx hatch
Ok so I got home from and I went to move my mustang(it was parked facing the wrong way on the street and I got a fine) and I put the key in the ignition and turned it to the on position to unlock the steering wheel so I can push it and the dome light was very very faint. I just put a new battery in it this morning and it seems like its dead. So it must be my alternator then?
Old November 16th, 2011, 01:25 AM   #6
Cgross609's Avatar
93 Mustang LX 2.3 T-5
Cgross609 is on a distinguished road
Not necessarily. Your starter might be fried, since the positive wire from the battery goes into the starter solenoid. If i were you i would take a look at my starter first. Check your ground connections as well. If it wasnt't charging when you were driving then there is a discontinuity of power somewhere. Starter is your best bet.
93 2.3l LX
U.S. 15x7 ten hole rims
Calypso green
Moates QH
T-5 Conversion
Dual 2.5" Exhaust with Thrush Welded muffler
Old November 16th, 2011, 12:27 PM   #7
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
I am going to have to say that your best approach is to check for bad connections everywhere, ground and positive side. It may have a bad alternator, but that could be cause by bad connections forcing the alternator to work its ass off, and in turn burning it out. If it has a good battery and the lights are dim, it is MOST LIKELY a connection issue. I hope you get it figured out.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old November 16th, 2011, 01:52 PM   #8
1992 2.3l lx hatch
I replaced my starter about 7 months ago so that shouldnt be the priblem. We will see. Hope I get it figured out. I have to work tomorrow.
Old November 16th, 2011, 03:37 PM   #9
1992 2.3l lx hatch
Alright giys, thanks so much for the help.....it started!!!!! It was a connection problem. I went and bought some new battery conncetions put them on the new battery and startes right up.the volt meter was alittle low at start up up butits reading now alittle under the middle. I decided to switch the headlights on just to try it out and when I did the volt meter went down. I think I might still meed an alternator. Is there a way to test it without takn
Old November 16th, 2011, 03:39 PM   #10
1992 2.3l lx hatch
Taking it off and take it to get tested? I heard that if you start the car, remove the negative battery cable from battery, and if it stays on ypur alternator is good. Of it tirns off its bad. Is that true? Sorry I hit the post reply button on accident.
Old November 16th, 2011, 06:02 PM   #11
So it was the connection between the battery and the solenoid. That is why i had said about the postive cable to the solenoid. In the past had a ford escort replaced battery, starter and come to find out it was that stupid red wire.
Old November 16th, 2011, 09:17 PM   #12
1992 2.3l lx hatch
Volt meter reads normal now. Yeah it was the connection but th he meter was still low so I took the alternator off and got it tested. It was fried so bought a new one and its fixed. Thanks for the guys. I knew I could count on this forum to help solve the problem. Thanks again
Threads Similar to: Battery meter at zero, changed battery and still nothing
battery terminals seized to battery BossOfDaRich Audio/Video 3 November 30th, 2010 10:48 PM
Battery light on...bad battery?? Nightmare69 99-04 22 November 9th, 2010 12:46 PM
How To Use Digital Volt Meter To Check Battery Driain?! svtkidd23 General Tech 4 November 6th, 2008 11:42 AM
Battery ebo 4356 96-98 9 August 28th, 2007 08:15 AM
battery relocation with second battery onewinner 5.0 Mustangs 1 May 30th, 2007 11:30 AM
