1991 2.3L DIS - Intermittent Check Engine
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old December 1st, 2011, 07:56 PM   #1
Look Ma! My First Post!
91CAStang is on a distinguished road
1991 2.3L DIS - Intermittent Check Engine [Resolved]
Hello, I have a 1991 Mustang - 4 cyl 2.3L DIS
We are nearing the need for a California smog check, but are experiencing an intermittent CEL condition. This has persisted for several months. I did both a KOEO and a KOER test, sending the pulses to the CEL.
For the EO test, I seem to be getting three "1" flashes, followed by a very long pause, then three "1" flashes again, another very long pause, then a "1", long pause, then "172".
For the ER test, I get an immediate "2", then the idle fluctuates a bit between about 1k and 1.2k. When idle drops down into the 700 range, I get a "1", a long pause, then the CEL flutters very quickly, a pause, then the following series:
172
411
538
536
521
[long pause]
[repeat above numbers]
[end test]
My pop suggested an O2 sensor, but code 172 suggests O2 sensing lean to the right side. Is there 2 sensors on this car? Should I swap them to see if the side code changes? I guess the rest of the codes are due to me not interacting with the ER test. Any help appreciated!
Edit: This was resolved. Single upstream O2 sensor replaced ($43). Did a full tune-up. CEL has stayed off now for about 4 days.
Threads Similar to: 1991 2.3L DIS - Intermittent Check Engine
check engine 99redstang V6 Mustangs 6 April 6th, 2011 06:44 PM
Check engine BDaily V6 Mustangs 5 January 13th, 2008 03:01 PM
Check Engine skimboard71104 V6 Mustangs 2 November 26th, 2007 05:29 PM
check engine mmvi V6 Mustangs 18 June 6th, 2007 07:05 PM
check engine cali 5.0 5.0 Mustangs 2 August 11th, 2006 11:13 PM
