Going To Carbed 2.3
So all this wiring non-sense is driving me crazy with this 2.3 turbo swap so i think im going to take a step back and do a carbed setup.
I need: -A carb adapter -carb. (350-390cfm) -carb. hat Am I going to need a new fuel pump? ALso will I need a different distributor than the EFI one I have in right now? PLease let me know if im leaving anything out. -Brandy |
Supercharged 89'/ 85' SVO
11.945 @ 119.6
Brandy, I don't have much time now, but I will post later on this, since I have done this countless times. If you are boosting less than 12 PSI, then you can use a stock mechanical fuel pump as a pressure compensation valve, by drilling and tapping a hole in the top of the pump housing and running a hose from the pump to the pressure bonnet, but your block may not have provision for the mechanical pump. Using a Maserati Bi Turbo pressure regulator is also a possibility. What the hell am I talking about? More later....
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
I was thinking for on an electric universal pump. But how many gph would I need?
11.945 @ 119.6
Look on Ebay for one of these. Maserati bi-turbo fuel pressure regulator.
![]() Look on Ebay for one of these. Amazon has these. ![]() The Carter GP5001 model pump flows over 227 gph and is preset at 20 psi, which you will need in order to compensate for boost pressure. Carter GP5001 - Carter In-Line TBI Fuel Pumps - Overview - SummitRacing.com
Threads Similar to: Going To Carbed 2.3
| V6 to carbed | Mach Stang | V6 Mustangs | 31 | April 12th, 2011 11:35 AM |
| carbed 4.6 | ford6693 | 99-04 | 16 | March 2nd, 2010 07:37 AM |
| MSD Carbed 5.0 | gtstang87 | 5.0 Mustangs | 0 | November 18th, 2007 07:13 PM |
| 5.0 EFI to 5.8 (carbed to EFI) | SVT Town Car | All Other Vehicles | 12 | July 8th, 2007 09:41 PM |
