89 2.3L With 86 TC Turbo Swap
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 3rd, 2012, 12:33 AM   #1
98 GT, 89 LX 2.3L, 88 GT
skaskater1 is on a distinguished road
Sorry to make a post if theres a million covering the topic but im in the middle of pulling the turbo manifold and exhuast piping from an 86 turbo coupe to put on my 89 2.3L and im just trying to figure out what all i need besides the givens, like pistons and ecu, the car currently has 19LB injectors from a Mark VII (atleast i think they are 19LB) a stock 94 5.0 throttle body and a slightly ported upper manifold.
My main question is with the injectors hold if i dont up the boost or do anything crazy just so i can set it up and get it running, i plan on putting the old 24LB injectors from my 98 gt in it when i swap them out, the car is purely a project that will barely get driven.
Next question is do i need the MAF or would i be better off using my ECU with a Tweecer or Megasquirt system? Mine is currently a speed density setup.
Does anyone know how much boost my pistons can handle if im not stomping the gas everyday?
any other tips would be greatly appreciated as well. Thanks
98 GT, Intake, Catless X Flowmasters, Predator tune, Screamin Demon packs, Roush 9MM Wires,BBK 78MM Throttle plennum, 03 Mach 1 front struts, Strut tower brace, 2in drop springs,BBK Underdrives.
89 LX 2.3L Some bolt ons.
Old January 3rd, 2012, 11:18 PM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
5-6 PSI would be a reasonable limit with the factory cast pistons. If the 86' is still in the yard and you dont have the vane air meter and the injectors from it, you might want to double back and get those items as well. Look in the FAQ section for turbo 2.3 swap for lots of useful info. The 24# injectors are a bit small for this application, even with low boost, so if you can snag the one's from the turbo coupe, I would advise it.
Supercharged 2.7L
398 HP
501 ft lb !!
Old January 6th, 2012, 04:30 AM   #3
Ok thanks thats what i figured so i did nab the injectors, after a few hours of research i started looking into using a non metered air system with the Pimp ECU from Stinger, but you never know plans might change, OHC i also plan on using a FMIC will that change the amount of boost that can be handled?
Old January 6th, 2012, 06:22 PM   #4
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
No a FMIC will not help get higher boost. The pistons can only handle so much force, and cooling the intake air wont change that. You will need better pistons before trying to go any higher.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old January 9th, 2012, 09:58 PM   #5
ok thanks, ive found a full turbo motor from a merkur that i may be getting so i might just do a swap for it, we will see how my luck runs thanks for the info guys, if i do get the merkur motor ill be looking to make my current motor a 2.5 turbo motor.
Threads Similar to: 89 2.3L With 86 TC Turbo Swap
93 2.3 turbo swap 00quicksilver 2.3 Mustangs 8 May 2nd, 2011 10:20 PM
when doing a swap from 2.3 n/a to turbo 1989stang 2.3 Mustangs 1 October 29th, 2010 12:35 AM
2.3L turbo swap Ghosnj 2.3 Mustangs 1 July 29th, 2010 11:29 PM
V6 to 2.3 turbo swap? plak424 2.3 Mustangs 3 May 19th, 2010 03:32 PM
My turbo/T5 swap is nearly done BigBlockFairlane 2.3 Mustangs 9 September 23rd, 2009 10:46 AM
