1988 Mustang vert 2.3L
5.0L throttle body on 2.3L
so ive been reading about people mounting 5 0 throttle bodys on 2.3 stangs.. i know it can be done.. has anyone does this?? im going through the process of getting the supplies i need to port my upper intake and figured these long winter nights i could set it up for this while i was at it...
Supercharged 89'/ 85' SVO
11.945 @ 119.6
I can't recall, is your car turbo'd? Anyway, I can take some pictures for you tonight when I get home of the larger throttle body installation.
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
id appreciate it... my car is n/a at the moment... i got a cylinder head off of a circle track car that has 1.89" int. and 1.59"exh. valves and is angle milled .100'-.105'' and is ported and all that stuff... im looking to run a stock roller in it for now and possibly gutt the upper intake and run maybe a bigger throttle body... im still thinking im gunna need the quarter horse as id be running 19 pounders or bigger on the injectors on a speed density motor...
11.945 @ 119.6
This is a typcal 5.0 TB installation. It involves drilling extra holes in the 5.0 throttle body, using a gasket from both throttle bodies as a reference. This really doesn't make a performance difference unless you have a boosted application or you are running a pretty big cam in an N/A application with a highly modified head.
In the middle photo you can see the stock throttle body for comparison. Unless you have access to machining equipment, you will need to take the upper intake to a machine shop to have the hole behind the throttle body bored to match the new throttle body. The manifold in the picture has been highly modified on the inside and features a large open plenum area on the lower half of the intake. ![]() ![]()
1988 2.3L Hatch
Ha-Ha
OHC, can the cam style throttle cable be used from a SN95 instead of the ball and stud?
11.945 @ 119.6
We did do one like that using the cable assembly from the SN95 as well, so yes it should work.
98 GT, 89 LX 2.3L, 88 GT
do you guys know if a 4.6 throttle body would be worth it? and how i might hook up the iac sensor?
98 GT, Intake, Catless X Flowmasters, Predator tune, Screamin Demon packs, Roush 9MM Wires,BBK 78MM Throttle plennum, 03 Mach 1 front struts, Strut tower brace, 2in drop springs,BBK Underdrives. 89 LX 2.3L Some bolt ons. |
Threads Similar to: 5.0L throttle body on 2.3L
| BBK 78mm Throttle Intake vs Accufab 75mm Throttle Body/Plenum | andrewskaggs | 99-04 | 19 | June 11th, 2010 08:48 AM |
| throttle body | sk8flip67 | 99-04 | 5 | April 15th, 2008 01:33 PM |
| IAC BAD??? OR throttle body bad? | Rico-mofos | 99-04 | 10 | March 12th, 2008 06:32 PM |
| Throttle body | Tony_90fox | 5.0 Mustangs | 5 | May 4th, 2007 11:33 AM |
| just put throttle body on | k2boarder3187 | 96-98 | 10 | April 25th, 2007 09:05 PM |
