Is the Capri Rs 1983 similar to SVO
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 12th, 2012, 11:39 PM   #1
1965 Mustang convertible
geofferito is on a distinguished road
Sorry if it's been asked before. I'm thinking of getting a 1983 Capri RS.
Is it pretty much like the SVO engine ?
Old January 12th, 2012, 11:44 PM   #2
I did find this FAQ ? ? which has lots of details, but what else should I be careful of ?
Old January 13th, 2012, 10:21 AM   #3
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
The 83 Capri RS turbo was essentially the same car as the 83 turbo Mustang GT with the exception of the body panels. They were rated at 145 HP and 175 HP respectively. There were less than 400 of these produced making them very rare these days, which apparently has nothing to do with their value??
The SVO Mustangs were fitted with a few parts that didn’t make their way into the Capri or other Fox body platforms. The SVO had a different steering ratio 15:1, unique spring rates, Koni adjustable shocks, front suspension geometry was modified, the rear lower control arms were different, five lug, 16X7” wheels were standard with four-wheel-discs, the foot pedals were moved closer together, a limited slip, 3.45:1, 7.5" Traction-Lok axle was added for the first year of production (later models used a 3.73:1 ratio. Ford used a different cam in the SVO and obviously it was intercooled as well. Other than the cam, the internals of the 83-84 RS turbo’s are the same, meaning they take to modifications quite well.
Problem areas in older Fox body cars are the same. Look for rust prone areas of the body. If the car has been sitting for a long time, rust in the fuel tank may be an issue. Corroded wire terminals are a common problem on early Fox body cars as well. Other than that, it's standard stuff you'd find on any older car.
Supercharged 2.7L
398 HP
501 ft lb !!
Old January 13th, 2012, 11:28 AM   #4
Thanks for the info. I will see if it's too far gone.
Threads Similar to: Is the Capri Rs 1983 similar to SVO
Trade LM-1 for LC-1 or similar? jkolbfleisch General Tech 1 February 3rd, 2011 05:06 AM
Anyone have a tune for a m90 or similar s/c? quadracer786 2005 - 2010 19 October 25th, 2010 04:48 PM
anyone have this? or something similar.. ? 006leenstang00 4V / SVT 4 October 27th, 2008 04:29 PM
Help Me-Looking for rims similar to these The Novice 5.0 Mustangs 8 June 9th, 2008 11:01 PM
1983 Mercury Capri firefly1241 5.0 Mustangs 4 May 5th, 2008 10:58 AM
