A few electrical issues
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 13th, 2012, 03:05 AM   #1
97gtstang is on a distinguished road
Headlights do a bit of a wig-wag action when pulling the lever which is cool, but won't get me past inspection (although it did last year?). The drivers bulb stays on high when dims are on and when using the flash to pass, but when flipped to bright position, it goes to the normal level. Passengers bulb works normal. High beam light on cluster does not light. Is it a bulb issue (I know I replaced atleast one bulb but can't remember if I did both or not), or a switch issue. Looks like the fuses are ok
Second issue, radio was working perfect yesterday, took car in for some welding work. Today when I picked up the car today and radio no longer works. Well the display works great, but no sound from radio. Also seems like it isn't picking up the signal, as it will stay on perminant scan. Could the welding have caused a short? It's a premium sound optioned car with the amp under the seat.
Hazard lights blink but are almost non visible, it's like the bulbs are not getting very much electricity. New flasher needed or bigger problems?
Won't have time to work on car until next week but wanted to hav a place to start when I did.
07 Roush Fastback Package
93 2.3 LX project car!
They all think it has a 5.0 ... n00bs
Old January 13th, 2012, 11:02 AM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
check the multi-function switch (lever) as it may be malfunctioning on you. It will control most of those things that you are mentioning dealing with the lights and flashers. As far as the radio is concerned where ever the antenna is mounted on the outside were they in that area doing some welding?
BUILD 2 IN PROGRESS
Old January 13th, 2012, 02:40 PM   #3
I did pull the switch lastnight. It was very greasy and dirty but I didn't have the special torx bit to open it up and look inside. Should I just purchase a new switch? The welding took place on the drivers floor pan so I was at a loss. I pulled the radio to make sure the cable was in too. I'll try a tape in the deck and see if I get sound
Old January 13th, 2012, 10:32 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah, the switch could be the culprit. If it isn't too expensive then I would just replace it especially if it is loose. as far as the radio goes try taking a piece of wire and attaching it to the radio then to a new ground on bare metal. Ive seen radios that werent getting a good ground and would try and pull ground from the antenna, problem is that when it does that the connection isnt great cause its not actually a grounded spot and would cause those symptoms that you are experiencing. not saying that it is it but its worth a try.
BUILD 2 IN PROGRESS
Old January 17th, 2012, 02:19 AM   #5
I pulled the switch apart and tried to clean up the inside, no go so I guess I'll have to drop atleast 100 for a new one. I'll have to check out the radio in a few days. Thanks for the help thus far
Old January 17th, 2012, 10:00 AM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
no problem. Check local junk yards as well or on the other forums
BUILD 2 IN PROGRESS
Old February 9th, 2012, 02:49 AM   #7
Hahahaha. Finally got some time to work on the issues and I started replacing the headlights since I had new ones and the car was in the garage. Got the new ones put on, ordered a used switch but the same issue prevailed. Turns out the jacka$$ had put a 9007 headlight in the drivers side, not the proper 9004. Easy fix and now they work great. Radio is on the back burner because I am picking up a replacement t5 but I have a feeling it's the ground as you said Wratherx. Do you know where the ground on the chassis is for that?
Threads Similar to: A few electrical issues
Electrical issues 84GT-306 5.0 Mustangs 0 April 11th, 2011 01:09 PM
electrical issues please help 89foxboy 5.0 Mustangs 11 December 12th, 2010 03:03 PM
Electrical Issues CheyenneMustang V6 Mustangs 5 August 31st, 2010 12:21 AM
Electrical Issues 96gtstang&V6 96-98 3 August 11th, 2010 02:46 PM
electrical issues 86ttops 96-98 2 July 2nd, 2009 02:53 PM
