Bought new parts, but volts are still low.
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 18th, 2012, 10:37 PM   #1
Former4banger's Avatar
1992 2.3l lx hatch
Former4banger is on a distinguished road
I replaced my alternater, battery, and battery terminals but my volt meter is still reading really low. Any thoughts or suggestions?
Old January 20th, 2012, 09:30 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
First a question. How low is the voltage? A good way of isolating this problem is by starting at the power source working your way out. Disconnect the battery cables at the battery and check the voltage, then do the same with the alternator disconnected, then pull all of the fuses from the fuse box and replace them one at a time to look for a power drain. I suspect you have a bad ground or a partial short somewhere in the electrical system. Try isolating the various system and re-post if you don't find the problem.
Supercharged 2.7L
398 HP
501 ft lb !!
Old January 23rd, 2012, 04:03 PM   #3
1993 Mustang LX 2.3L
N/A
1993MustangNotch is on a distinguished road
Yep I was gonna say bad ground. Do what he said ^^^ check everything.
Old February 28th, 2012, 02:00 PM   #4
4themasses's Avatar
4themasses is on a distinguished road
Does your "AMP" light turn on when you first turn the ignition on? My AMP bulb was out creating a voltage issue. The SVO instrument cluster is special to the charging system in that if that bulb is out, you will get about 12V.
Had the same issue, did some diggin around and that was the issue...back up to over 14v.
Threads Similar to: Bought new parts, but volts are still low.
460 amp volts? sportsguy0502 Audio/Video 2 March 15th, 2012 09:38 AM
Just bought this car with these parts Gearhead177 5.0 Mustangs 5 April 18th, 2010 05:02 PM
Bought some new parts for the 01 89StangGT 4V / SVT 14 February 15th, 2010 06:46 PM
bought some new parts today.. e3sean 5.0 Mustangs 38 May 20th, 2008 06:22 PM
Volts cobralini General Tech 4 May 23rd, 2006 11:00 PM
