1988 Mustang LX 2.3T
2.3L Problems.
Ok so heres my problem folks. Rebuilt a 2.3L engine had a higher performance cam put in, port and polished the head, new header, and some other random stuff. I'm slowly replacing stuff as needed to try and fix my current problem and was hoping someone here might be able to help me. When I go out in the morning and start my car it starts fine and runs fine for the most part. Now once I start driving it and get it to tac 4k rpms the car starts having a miss. Through all rpms and all gears till the engine warms up and eventually the miss goes away and doesn't show back up. I replaced the ignition coil, spark plug wires, and spark plugs thinking it was somewhere in there. So anyone experience or know what might be causing it?
Edited - 1987 2.3L engine. 1988 Body. |
well i really dont kno too much about the actual mechanics of the engine but if u adjust ur timing and take the knock sensor off it might help
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
Timing has been set as best as it can be. When the miss isn't happening the car runs fantastic its just the initial startup and reaching 4k rpms.
As for the knock sensor wtf is that and where is it?
1988 Mustang LX Turbo
the cylinder mite be MISS-Firing, problably because the valves arent opening properly or are staying shut some times
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#6 | |
what kind of cam do you have? whats the lift and has it been properly broken in?
The specs and such will be posted soon as I get a 100% answer on what cam it is. Effin mechanic won't give me the info for some effin reason so I'll post it soon as I can.
Ok well after long delay heres the cam Specs.
Its a Speed Pro CS1156R Hydraulic Camshaft. Ford 2.3L Hydraulic camshaft, 1500-5000 rpm range, adv. duration 282 intake/ 282 exhaust, duration @ .050 of 220 intake and 220 exhaust, valve lift of .454 intake and .454 exhaust, Lobe C/L is 112. Thats from summit and here is what we were told it was. Camlift Int. 270 Ex. 270 Valvelift Int. 454 Ex. 454 Duration @ .050 lift 220/220 @ .050 lift 282/282 Lobe C/L 112 Overlap 45 So lets try to get the pony running correctly. |
so its basically a stage 2 cam?
rough idle, power in the 3500-6200 with those specs or am i thinking of something else?
It idles fine in its current state. It just that god forsaken misses that pisses me off that i'm trying to fix. As for power it picks up about 2-2500 rpms. Redline on the car is about 5500 rpms if I recall correctly. Dunno never wound the car up past 5000. Regardless cold start tack 4000 rpms and a hard miss comes into play and stays there till the engine warms up. TurboLX was saying the valves aren't opening properly or staying shut some times which could be causing it. He asked for the cam specs so here they are. Hopefully this will give enough info to try and get this car purring instead of gagging and puking.
Edited - Forgot the major changes to this engine are the cam, port and polish and the head was shaved like .080 of an inch or something close to that. |
well, all 2.3s pick up power at 2-2500 cuz the torque peak is 2400 rpms lol
and it lasts until 5k cuz thats where the hp peak is lol well, did u get valves with the cam swap? i wud've definitely done that if i got that cam
#15 | |
#17 | |
#18 | |
#19 | |
Valvelift Int. 454 Ex. 454 Duration @ .050 lift 220/220 @ .050 lift 282/282 Lobe C/L 112 Overlap 45 |
Threads Similar to: 2.3L Problems.
| problems plz help | cams-shelbycobra07 | 2005 - 2010 | 6 | June 14th, 2007 12:27 AM |
| more problems | ks_emt | 2.3 Mustangs | 7 | June 7th, 2007 04:16 PM |
| EEC IV problems | tekt | 5.0 Mustangs | 3 | February 19th, 2007 02:00 AM |
| 88 GT With A Few Problems | Iceman1989 | General Tech | 3 | November 14th, 2006 01:58 AM |
| Help Please (Car Problems) | 98mustang98 | V6 Mustangs | 1 | October 25th, 2006 11:49 PM |
