2.3L roller cam??
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 21st, 2012, 12:05 AM   #1
1988 Mustang vert 2.3L
Smokestang88 is on a distinguished road
2.3L roller cam??
ive been searching for a roller cam for some time out of a stock 91-93 stang or dual plug ranger... what are the specs on them stock cams of them years and what is the specs on a cam out of a 88 stang? some one told me they all have roller cams but im not believing it.. and also how do ya tell the difference on the rollor and flat tappet camshafts?
Old May 1st, 2012, 02:14 PM   #2
Look Ma! My First Post!
Fox_2.3 is on a distinguished road
Post
if you have not already figured out,
Not all 2.3 fox's have a roller cam and roller followers.. i have removed the valve cover from my 89 2.3 more times than i can think of.. but as to the difference i couldn't tell you..
hope this helps!
Old May 4th, 2012, 02:06 AM   #3
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Here are the ROLLER cam specs on the 88'-97' and up "Dual Plug" engines. Single plug engines were offered in Mustangs up to 1990.
Do you have a specific goal in mind with the roller cam?
Cam Lift (Intake):.216"
Cam Lift (Exhaust):.216"
Valve Lift (Intake):.355"
Valve Lift (Exhaust):.355"
Duration at .050" Lobe Lift (Intake):189 Deg
Duration at .050" Lobe Lift (Exhaust):186 Deg
Supercharged 2.7L
398 HP
501 ft lb !!
Old May 8th, 2012, 01:19 PM   #4
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
If you want performance, buy an aftermaket cam, but take into consideration the modifications that you will have to make to the fuel and fuel management systems.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old May 8th, 2012, 09:49 PM   #5
94 GT Vert, 86 SVO
79'293stang is on a distinguished road
Aftermarket roller cams for the 2.3 are expensive, I run a BoPort 1.9 roller cam and love it, worth the money in my opinion. Do not be to disappointed if you get a roller cam from a ranger or mustang and don't notice any difference in power.
94 GT convertible - GT40's, F cam, Kenne Bell blowing 10 lbs, etc.
Threads Similar to: 2.3L roller cam??
Solid Roller vs Hyd. Roller 68 dlxcoupe 5.0 Mustangs 14 June 8th, 2009 12:39 AM
Solid Roller vs. Hydra Roller Goblin 5.0 Mustangs 58 November 30th, 2007 02:22 PM
Hydrolic roller to Solid/Mechanical roller hitorx 5.0 Mustangs 2 May 14th, 2007 05:12 PM
roller vs. non roller block DJKING 5.0 Mustangs 11 March 29th, 2007 11:53 AM
