1988 Mustang vert 2.3L
Camshaft question.. need more info
so since buying this built head off of my uncle over a year ago i decided to start disassembling it and get it ready to get thermo cleaned throught my local machine shop.. i pulled the cam and on one end the markings are CWC and more towards the front theres another marking of EP 311.. i cant seem to find any info on this cam and was wondering if anyone had a clue what brand this is and other stuff... id appreciate any useful info..
that should be a Comp Cams number, i think it is anyway.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
I can tell you that its probably just the casting number, and if you want to know the specs you should just measure it. If you have the right tools.
how do ya measure a camshaft? what tools do ya need to measure it?
#5 | |
To measure the lobe lift its easy, take your mic, or caliper, and measure the base circle, do this on the sides if you have the lobe pointed up. then measure top to bottom at its tallest point. Subtract the base circle measurement from the lobe height measurement and you get the net lobe lift. then multiply it by the rocker arm ratio to get the theoretical valve lift ( there will be less than your figured number due to lifter movement)
93 Mustang LX 2.3 T-5
Just got the same one. Its a Comp Cams 268H hydraulic flat tappet.
70-127-6 - Magnum? Hydraulic Flat Tappet Camshafts
93 2.3l LX U.S. 15x7 ten hole rims Calypso green Moates QH T-5 Conversion Dual 2.5" Exhaust with Thrush Welded muffler
I personally think if you are going to build a good engine, you should just buy the $1000 complete head overhaul kit from Esslinger. It comes with eveything to build a badasss head for the 2.3.
It comes with everything but the head?
Yessir, Cam, cam followers, valves, springs, mousetrap springs, cam tower straps, valve keepers. the only thing you have to buy is the solid lifters. and th machine work to get it all to work.
Threads Similar to: Camshaft question.. need more info
| Camshaft Question | HLNEZ | 2005 - 2010 | 1 | November 9th, 2011 07:54 PM |
| Camshaft Question | brett22 | 99-04 | 0 | March 8th, 2011 11:43 PM |
| Camshaft Question | mustangmanic | 99-04 | 17 | November 28th, 2007 01:39 PM |
| Question about camshaft | BumbleBeeStang04 | 99-04 | 16 | September 12th, 2007 01:06 PM |
| Camshaft question | energiesource | 99-04 | 3 | July 28th, 2007 05:29 PM |
