Pros and Cons decking/milling the head Help
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old February 6th, 2012, 05:42 PM   #1
basic_390's Avatar
93 4 banger
basic_390 is on a distinguished road
I was planing on decking the head on my 93 2.3 mustang .050 i know it increases CR and hp power but it there any negative like very bad idle or gas mileage also 5 angle valve job, tuner and maybe small cam .im trying to keep it cheap
Old February 7th, 2012, 08:44 AM   #2
ranger50toy's Avatar
1988 2.3L Hatch
Ha-Ha
ranger50toy is on a distinguished road
Milling will change your cam timing. You will need adjustable cam gear to correct it.
Old February 9th, 2012, 11:00 AM   #3
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
or you can just take .150 off the head and have better compression! and he is right it does change your timing, ive been told 1 degree per .025" (makes the cam work that much later) so you dont really need to get one, i run my ranger with .150" off and a stock cam gear, but each tooth is 10 degrees, so i either run 6 degrees retarded or 4 degrees advanced. I change it sometimes. The other issue is spark knock, i have bad spark knock with 87, i have to use 89 or higher to make it go away.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old February 9th, 2012, 11:03 AM   #4
1991 Mustang 2.3L
I also run my mustang with the 4 plug head at .150 shaved, but i have an adjustable cam gear for that one. i dont have it run strait up with stock timing though. I think i have that one running about 2 degrees retarded, it changes where your power is made is all. retarded= higher rpm power and less torque, advanced = good low end torque and lower rpm hp.
Threads Similar to: Pros and Cons decking/milling the head Help
carb pros and cons itsjustamustnag 5.0 Mustangs 4 March 5th, 2011 01:09 AM
pros and cons of internals kennyGT 5.0 Mustangs 2 September 8th, 2009 04:18 PM
3.73 pros and cons? fasterv6 V6 Mustangs 24 August 12th, 2009 10:03 AM
pros and cons zinc02GT The Clubhouse 11 June 24th, 2008 12:28 AM
Pros and Cons of the V6 05 SDS V6 Mustangs 137 March 24th, 2008 08:49 PM
