Head work vs mpg
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old February 7th, 2012, 07:47 PM   #1
Jackal13 is on a distinguished road
Head work vs mpg
I have a dual plug head. What is my best option for cleaning the head. I talked to a shop, they would port & polish the head for me. Wouldn't that open the ports bigger and then the stock cam wouldn't work in it's range? If stage one cam is needed wouldn't i bigger injectors to match the cam and defeating my main goal, mpg?
Old February 8th, 2012, 08:53 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
It really depends on the shop doing the work, but you are right, any significant HP gains would need to be accompanied by adjustments in fuel trim. The good news is; both dual and single plug heads have choke points which can be relieved by porting, without adversely affecting velocities. Finding a shop that has the technology to perform the work or patience to listen to their customers, might be challenging though. You might want to contact BoPort racing in Fremont CA. Below are scanned images of a 2.3 port, before and after performing a street porting job. The work below, will consistently produce a 15% increase in HP and torque when combined with some surface milling, on an otherwise stock engine. The valve seats are finished with a 5 angle seat and the valves are back faced with a 15 degree cut as well. (not depicted here) Fuel economy is consistently better with these mods.
Supercharged 2.7L
398 HP
501 ft lb !!
Old February 8th, 2012, 03:03 PM   #3
So basically boport stage 1&2 (stock valves) and mill down to get 10:5 compression? For n/a head?
Stage 1 porting
The best bang for the buck porting option if you are on a budget. Our stage 1 port usually outflows other shop's FULL porting. This level of porting focuses on blending of the valve seat angles into the bowl and short turn of the port, where the largest airflow gains are achieved (even more-so with oversized valves).
Cast Iron- $299
Aluminum- $249
Stage 2 Porting
Same as our stage 1 porting, with the addition of work performed around the guide bosses and some valve unshrouding in the combustion chamber for further flow gains.
Threads Similar to: Head work vs mpg
89 head work sam89 2.3 Mustangs 6 June 6th, 2011 08:59 AM
Gimme some head work 281SLEEPER2v 99-04 5 November 27th, 2010 12:23 AM
Head work J0rn3z 5.0 Mustangs 26 January 14th, 2009 10:55 AM
head work? motorhead6776 V6 Mustangs 18 March 14th, 2008 02:16 PM
head work machy V6 Mustangs 2 July 26th, 2006 08:34 AM
