84 ranger carb upgrade?? help...
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old February 9th, 2012, 11:36 PM   #1
skippy84's Avatar
1993 mustang 4cl
n/a
skippy84 is on a distinguished road
k i have an 84 ford ranger with a 2.3 n/a in it. the motor went out on me a few years ago so i installed a block from a 93 mustang and had the 84 head rebuilt with cam and rollers from the same 93. the truck ran great but the carb is going out now and i am tired of rebuilding these things. and found out that there are no real upgrades as far as carb unless i go drastic or spend lots of cash. my next bet is i have a rebult head out of an 88 mustang and a lower intake manifold for it too. i am about to get the adapter for a carb setup for it but was wondering what carb should i go with. i am thinking a 2bb but what one? and howmany cfms can it handle.i also have tube headers from a newer ranger that are going in it too. its going to be a daily driver so i dont want to go too crazy. any ideas? also what kind of ignition setup should i go with? or should i just keep the one i have.?
Old February 10th, 2012, 10:24 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Unless you plan on building something for high performance use, the Holley Weber 5200 series 2 barrel carburetor is hard to beat. It will provide excellent throttle response and reasonable economy, while still giving decent performance. 4 cylinder Mustang II's will have the donor parts you need to do the swap. If you are hell bent on using a factory Ranger header, search for a 98-01 Ranger Casting # F87E-9428-CB. It is by far the best of the factory manifolds I've tested.
Supercharged 2.7L
398 HP
501 ft lb !!
Threads Similar to: 84 ranger carb upgrade?? help...
Ranger That! Averlus The Clubhouse 6 March 26th, 2010 04:29 PM
86 Ranger smoke-em The Clubhouse 9 June 5th, 2009 02:54 PM
99 Ranger help Spiderz All Other Vehicles 0 April 20th, 2009 06:09 AM
91 ranger 40thmustanggt All Other Vehicles 0 January 3rd, 2008 10:06 PM
need help 91 ranger 40thmustanggt All Other Vehicles 1 August 15th, 2007 05:06 PM
