Car Computer
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old July 5th, 2007, 06:45 PM   #1
1988 Mustang LX 2.3T
akatagyourit is on a distinguished road
Car Computer
Well i'm back and so is the miss fire. The mechanic that currently has the car says there may be a problem with the computer itself to make this cam work. Now the question I have it, is there a way to put a tune on the 2.3L computer? If anyone can help it will be greatly appreciated.
Old July 5th, 2007, 07:28 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
www.twEECer.com
Old July 6th, 2007, 01:06 AM   #3
93fourbangerstanger's Avatar
93fourbangerstanger is an unknown quantity at this point
i just got done fixing my miss fire!!what is it doin?
93 fourbanger /intake,exhaust,erg delete,8 inch sub...for now
fukin gas prices!
Old July 6th, 2007, 11:16 AM   #4
TurboLX's Avatar
what was wrong with yours 93?
Old July 6th, 2007, 04:44 PM   #5
Eh I'm being told there could be a problem with the cam and the computer in my car and that I may need to get a tuner for it to allow the car to run correctly. Turbo told my the ignition coil could be causing problems for me with the cam so I changed it out and it solved that problem. Unfortunately the timing was off for the cam. The mechanic that has it now has said the top and bottom end of the engine are still good. The source of my problem is either the cam itself, or the computer might not be able to handle it. Regardless we're gonna get a tuner for the computer and see if it fixes it. If not i'll be gettin a new cam maybe more high performance one. Thanks for the help once again Turbo.
Old July 6th, 2007, 05:26 PM   #6
TurboLX's Avatar
try the tweecer out man, and beef things up a bit, also what siz injectors you running?
Old July 7th, 2007, 11:42 AM   #7
Still running stock injectors. None the less gonna do the tweecer and such and just keep upgrading stuff as needed and hopefully gettin the car running optimally
Old July 7th, 2007, 11:45 AM   #8
TurboLX's Avatar
hmmm you might wanna upgrade them 17* lb injectors then as well as a FPR
Old July 7th, 2007, 03:45 PM   #9
What does FPR stand for. Amongst other things The mechanic that was working on my car has kicked us out of their garage now, so we have to find a new mechanic to do the stuff we can't do ourselves so. yay. Tons of problems going on right now amongst things.
Old July 7th, 2007, 03:48 PM   #10
TurboLX's Avatar
FPR= Fuel pressure regulator.
any pics of the car yet?
Old July 7th, 2007, 05:28 PM   #11
I'll have the pics tomorrow for ya, probably inside and out less it ends up in another shop by tomorrow. So we'll see what happens. Headed home tonight since the car is sitting there waiting.
Threads Similar to: Car Computer
So My Computer Is Just Done... TurboLX The Clubhouse 38 November 11th, 2007 10:52 AM
More computer help Tony_90fox The Clubhouse 3 July 26th, 2007 02:24 AM
Computer akatagyourit 2.3 Mustangs 3 July 25th, 2007 12:02 AM
A8L Computer squirt 5.0 Mustangs 4 April 18th, 2007 01:39 AM
which computer is the best? cobraetti 5.0 Mustangs 2 October 19th, 2006 10:20 PM
