Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Discussing Pictures YAY in the 2.3 Mustangs Forum. no actually it helps it breath better...
Old July 9th, 2007, 11:57 AM   #21
1990 Mustang LX Turbo
9.71@141.6 mph
Old July 9th, 2007, 11:58 AM   #22
9.71@141.6 mph
deleted EGR valve??
how come it still shows it in them pictures?
Old July 9th, 2007, 12:24 PM   #23
I thought a deleted EGR valve was nothing more than putting a blocking plate there to stop it.
1990 5.0 LX - Manual (for play)
1991 2.3L LX - Auto (for street)
1989 2.3Turbo - In the Works
1988 Thunderbird Turbo Coupe 2.3Turbo - (K&N , Gillis Boost Valve, Auto to T5 SWAP )
Yeah I'm a mustang Newbie - wanna fight about it ?
Old July 9th, 2007, 12:25 PM   #24
9.71@141.6 mph
some people take them off but you could be right
Old July 9th, 2007, 02:57 PM   #25
MSO
what does deleting the EGR valve do?
[COLOR="Red"][B][SIZE="4"]Members Against Mods
Crew member #7[/SIZE][/B][/COLOR]
[SIGPIC][/SIGPIC]
[SIZE="5"][COLOR="Red"]Dean MSO[/COLOR][/SIZE]
Old July 9th, 2007, 02:59 PM   #26
9.71@141.6 mph
nothing
Old July 9th, 2007, 03:00 PM   #27
MSO
so wut's the point?
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 03:03 PM   #28
9.71@141.6 mph
emissions
Old July 9th, 2007, 03:07 PM   #29
MSO
nice, i like ur simple answers
now i have to ask a million more questions..
how does it affect emissions?
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 03:14 PM   #30
9.71@141.6 mph
just puts heat into the intake and recycles exhaust combustion
Old July 9th, 2007, 03:25 PM   #31
MSO
which in english means.. less HP?
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 03:35 PM   #32
9.71@141.6 mph
kinda
Old July 9th, 2007, 03:39 PM   #33
When you delete the EGR system, EGR gases are blocked from entering the intake, but the EGR valve is still set to function, so the EGR Valve Position (EVP) sensor related codes are not registered.
The Adaptive Performance EGR Eliminator plugs into your mustangs wiring harness to simulate the closed position of the EGR Valve Position value and prevent code 31 (EVP circuit below minimum voltage) from getting logged ,but codes 33 and 34 (EVP not opening )are registered.Why do we want this to happen? The EEC-IV logic will not allow the operation of the EGR system once the EVP 33 and 34 are registered. There by, no timing advance is added by the system, since the EGR function is bypassed.
Old July 9th, 2007, 03:41 PM   #34
MSO
so you gain hp by deleting it?
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 03:44 PM   #35
9.71@141.6 mph
damnnn that was well put, better then anything i would be able to explain, btw you get my PM?
Old July 9th, 2007, 03:47 PM   #36
MSO
we kno turbo
but we still dont kno the benefits, other than not having exhaust gas in your intake
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 03:49 PM   #37
MSO
okie dokie, you guys dont help, so i took it upon myself to find something
here is an explanation of what the egr does
EGR Theory. EGR serves one purpose and one purpose only. That purpose is to reduce Oxides of Nitrogen (NOx). Undernormal combustion, Nitrogen(N2)Oxygen (O2) in the air and Hydrocarbons (HC) in the fuel combind into water(H2O) Carbon dioxide (CO2) and the Nitrogen remains unchanged. Under very hot combustion temperatures, the Nitrogen reacts with the other two byproducts and forms Nitrogen oxide (NO). After being released into the atmosphere, it picks up another Oxygen and becomes Nitrogen dioxide (NO2). In the presence of sunlight,
it combines with other compounds like Hydrocarbons and forms Smog. Since exhaust gas is inert (very stable) it doesn’t burn again. So by being introduced into
the combustion chamber, it will lower combustion chamber temps enough so that
the Nitrogen doesn’t react with the other compounds and is passed unchanged out
the tailpipe thus not contributing to smog. Now, since exhaust gas doesn’t burn, it
doesn’t exactly help with combustion. At higher RPM’s, this really isn’t noticable,
but at idle, the reintroduction of exhaust gas will cause a very rough idle and can
cause stalling if to much is introduced into the combustion chamber
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 04:00 PM   #38
9.71@141.6 mph
to much science involved there
Old July 9th, 2007, 04:10 PM   #39
MSO
ha it basically says the exhaust gas keeps the amount of smog down
[SIGPIC][/SIGPIC]
Old July 9th, 2007, 04:26 PM   #40
9.71@141.6 mph
oh yes it does indeed
Threads Similar to: Pictures YAY
New Pictures DCstangGT Pictures 26 May 3rd, 2008 10:09 AM
looking for pictures? gregkelley Visual 11 July 18th, 2007 02:26 PM
some pictures of my 5.0 89StangGT 5.0 Mustangs 16 April 27th, 2007 07:35 PM
I need pictures please fordboy4rd 2.3 Mustangs 2 February 5th, 2007 05:42 PM
Some Pictures Sicc03GT Pictures 16 November 17th, 2006 07:00 AM
