Discussing Pictures YAY in the 2.3 Mustangs Forum. Well to my understanding the egr valves on my mustang is powered by nothing but ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 |
1988 Mustang LX 2.3T
Well to my understanding the egr valves on my mustang is powered by nothing but a vacuum. If you look at the right side of the engine at the egr valve you'll see a little colored nub sticking out, I basically plugged up the hole on the egr valve that caused the vacuum and the vacuum line itself. If this is not true then time to get to customizing.
As for how it helps to my understanding its introducing gases that have already been burned up in prior combustions. So if you eliminate it, theoretically speaking it should richen the motor up a little but you'll have nothing but clean air instead of polluted air with clean in your cylinders. Just my thinking I could be wrong. |
#42 | |||
#43 |
try a bigger fan lol
[COLOR="Red"][B][SIZE="4"]Members Against Mods Crew member #7[/SIZE][/B][/COLOR] [SIGPIC][/SIGPIC] [SIZE="5"][COLOR="Red"]Dean MSO[/COLOR][/SIZE] |
#44 |
or why don't you try heat wrapping the wires?
#45 |
Hmmmm I wonder I still need to put a low temp thermostat in the car cause I don't like hitting 210 degrees before that fan kicks on would that possibly bring down the heat on the header itself maybe just a little. New idea to thinking of cooling system that cools the header.......
#46 |
#47 |
We really need to get some soolid proven data locked in here somewhere. So we know who , what , when , where , why and how
1990 5.0 LX - Manual (for play) 1991 2.3L LX - Auto (for street) 1989 2.3Turbo - In the Works 1988 Thunderbird Turbo Coupe 2.3Turbo - (K&N , Gillis Boost Valve, Auto to T5 SWAP ) ![]() Yeah I'm a mustang Newbie - wanna fight about it ? |
#48 |
1990 Mustang LX Turbo
9.71@141.6 mph
dude you need to lower that theremostat if its getting that hot
#49 | |
And yes I should Turbo. Pretty sure once the car heats up its pretty much nothing left to go go. Also as for the other performance post you and MSO are making. WTF is up with that gears mod bs. My cars stock and at 70 mph i'm taking like 3k rpms. I wish I could get down to 1500 at that speed and just for reference i've never touched the rear end so i'm assuming its still stock. |
#50 |
http://www.thermaltechcoatings.com/
these guys will coat ur whole exhaust if you aint satisfied wit that.. wrap it then lol
#51 |
9.71@141.6 mph
put a fan switch and a 160* thermostat and you'll be good
#52 |
fan switch? what's that for?
#53 | |
#54 |
9.71@141.6 mph
get a switch with a light and you'll hear it on when you shut the car off
Threads Similar to: Pictures YAY
| New Pictures | DCstangGT | Pictures | 26 | May 3rd, 2008 10:09 AM |
| looking for pictures? | gregkelley | Visual | 11 | July 18th, 2007 02:26 PM |
| some pictures of my 5.0 | 89StangGT | 5.0 Mustangs | 16 | April 27th, 2007 07:35 PM |
| I need pictures please | fordboy4rd | 2.3 Mustangs | 2 | February 5th, 2007 05:42 PM |
| Some Pictures | Sicc03GT | Pictures | 16 | November 17th, 2006 07:00 AM |
