1988 Mustang LX 2.3T
Radiator Fan Relay
Where is it at? There is no box of relays in my engine compartment and there is no fuse in the fuse panel for the radiator fan. Where is the relay located? Worked my ass off on the car this week and now the fan doesn't turn on unless I set it on a ignition hotwire. Any help would be greatly appreciated.
Achieving more N/A power!
Isn't it inline with the wire?
Brendan '99 Mustang GT [ 318 rwhp N/A ] - SOLD ( )'04 F150 XLT SuperCab
#3 | |
1988 Mustang LX Turbo
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Well its not inline on my car... yay.....
Any luck yet turbo?
The car model is an 88 the engine is an 87.
lol, turbo is notorious for forgetting what he says
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
No more quote Turbo?
#12 | |
2005 Torrid Red GTO m6
hey
i had that same problem. it could be a few things. but first does it turn on when you turn the ac on? if not then its probably the relay or a bad wiring. the easiest and cheepes t way to get around it which is what i did run two wires to a switch inside the car and then run tweo more wires from that to your fuse box inside , just find a fuse thats only hot when the ignition is on, i think it might be 17 actually. but yeah youll be able to flip it on good luck bro
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
Well currently its wired in through the a/c which has been removed cept the wiring. Its currently set to turn on when the ignition is on. I don't like it running like this is due to the amount of time it will take for the car to warm up. I'm still awaiting delivery of the 180 degree thermostat so I can at least force the engine to warm up till that opens. None the less I don't like the fan running 24/7 puts a strain on the charging system specially at night. Fan + headlights + tons of stereo equipment = battery never gets recharged.
well than splice it off and rewire it like i said lol
it takes o about 20 mins. theres a grommet in the firewall where alot of the wiring for the dash and stuff comes in use that.
If I wired my fan like that I would be afraid that I would forget to turn it on...
yea it doesnt say where the relay is at in my book, i put a switch on mine with a double fan
Threads Similar to: Radiator Fan Relay
| Relay | akatagyourit | 2.3 Mustangs | 2 | July 21st, 2007 01:39 PM |
| fuel relay | Mustang RacR94 | V6 Mustangs | 3 | April 15th, 2007 06:24 PM |
| starter relay | terribleonexx88 | 5.0 Mustangs | 22 | December 4th, 2006 05:11 PM |
| PCM Relay and/or Ideas | David C | 5.0 Mustangs | 6 | December 4th, 2006 12:22 AM |
| WOT A/C Cutoff Relay | Cmauney | 5.0 Mustangs | 3 | February 25th, 2006 11:42 AM |
