Discussing Need an Cheap good Aftermarket intercooler in the 2.3 Mustangs Forum. ok im new here sorta i been roaming around here for a while but anyways ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Need an Cheap good Aftermarket intercooler |
1990 Mustang LX Turbo
8.67@165.91 mph
well first off, what turbo are you running??
The IHI or the Garrett T3 60/40??
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info Myspace Small Block Posse |
#3 | |
hehe, get 3 junkyard cores and weld them together
to tell you the truth i have no clue in what turbo is on it it a 86 Tbird motor with stock turbo i have no clue which one of the two it would be lol
8.67@165.91 mph
ok then its a Garrett T3
the most poular CHEAP intercooler is a Volvo one from the early style Turbo Volvos with the DOHC, find one in the junkyard and grab it, its a very excellent upgrade which most 2.3 guys are using
but i heard i need another radiator to go with it to is that true? btw i was hoping you would answer my questions to since your the expert on this part of the forums XD
8.67@165.91 mph
it would be best becasue theres no way to get the charge pipes into the FMIC, most guys can get away with it by using the stock radiator and going around or under them
u could try ebay...
8.67@165.91 mph
yes indeed but most of it is knock off junk
how would you make an intercooler
8.67@165.91 mph
get a core from a company that makes one, then weld the tubs to the side of it
#12 | ||
8.67@165.91 mph
was i talking to you?? duhhhh
#14 | ||
like a heater core if im wrong give me a link and turbo did you find anything that has 67mm turbos
8.67@165.91 mph
like a heater core yes, ill get you a link
no luck on the turbo, so far it looks like the diesel truck turbo might be best i saw a list somewhere for JY turbos but i cant find it
will my 10:1 compresion work
9:1 what I need right
#20 | ||
thats a good one
Threads Similar to: Need an Cheap good Aftermarket intercooler
| cheap aluminum driveshaft...good buy??? | Draztic1 | 2005+ | 10 | October 14th, 2007 02:15 PM |
| Any One Have A 5 Speed Fairly Cheap But Works Good? | 5.0guy | 5.0 Mustangs | 5 | October 23rd, 2006 10:52 AM |
| In need of a good/cheap clutch | 00SoSlow | General Tech | 1 | October 7th, 2006 02:52 AM |
| cheap mood that'll give me good HP | itschristorres8 | V6 Mustangs | 22 | August 26th, 2006 01:08 AM |
| Cheap Cheap!!! 3.73 gears minor chips... Buy It Now $45 M/O | 00SoSlow | V6 Mustangs | 3 | August 5th, 2006 10:32 AM |
