'91 hatch wont run, please help
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old August 6th, 2007, 01:27 AM   #1
'91 4-cyl hatch is on a distinguished road
buying a 1991 4-cylender 2.3l mustang hatchback from one of my dads coeworkers, the reason why he is selling it is that it wont start. the problem is that it started off having trouble starting over time, but once it had started it ran great (so he said, hes not much of a car guy), and it slowly worked it way to where it wouldnt start. we have checked the battery, it cranks over, checked the gas pump and put a new one in, fresh gas, but still nothing. does anyone have any ideas on things that have happened to be wrong with these?
or at least could you tell me/help me out with were to check the timing on the timing belt? we thing the timing may be so far off it doesnt want to start, but then if tthat were the problem once it started wouldn't it have ran like crap? it would be the starter, but i dont think so... its got spark, its got fuel preasure, its cranking over fine, every once in a great while it will half-a$$ fire.
thanks for the help
Old August 6th, 2007, 01:32 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
sounds like it needs plugs, that or the starter is no good
Old August 6th, 2007, 03:50 AM   #3
hellion_79 is on a distinguished road
Send a message via Yahoo to hellion_79
It probly needs a good tune-up (cap, rotor, plugs, wires, fuel filter, and a airfilter)
PM me if you want me to make you a sig
Old August 8th, 2007, 12:59 AM   #4
ok, we bought a manual for the car, and we have come down to pretty much one conclusion.... the piston is not getting any gas. i'll tell you why...
1. has fuel preasure, fresh gas, gas is priming.
2. getting spark
3. engine is turning over when cranking it over
4. as it is cranking over, it is good and strong, but it acts like it is not getting any fuel since every once in a while (every 10 secconds) it sounds like it gets just a hint of fuel in the piston and barely fires up, only to start dry-cranking again.
so, does anyone have any suggestions only on what could be going wrong with the pistons not getting gas, what to check? the manual tells everything in sort of a confusing fassion, and doesnt help as far as what happens when something goes out (as far a i have read).
thank you, i know im kind of being stubborn just getting so frustrated, damn fuel injected engines!!!!
Old August 8th, 2007, 01:13 AM   #5
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
i'll take a wild guess here:
bad injector?
[SIGPIC][/SIGPIC]
Old August 8th, 2007, 01:19 AM   #6
TurboLX's Avatar
+1 on injectors
Old August 8th, 2007, 01:43 AM   #7
injectors or your timing might be off not letting fuel get to the cylinders.
Old August 8th, 2007, 11:09 AM   #8
MSO
OMGZ
i made a (semi) tech post!!
[SIGPIC][/SIGPIC]
Old August 8th, 2007, 11:50 AM   #9
TurboLX's Avatar
do exlain this
Old August 8th, 2007, 07:16 PM   #10
do exlain this
on the compression stroke, the timing could be messed up and letting air and fuel in one the way up.
Old August 8th, 2007, 11:21 PM   #11
TurboLX's Avatar
ok but do you know how badly the timing has to be messed up for that
Old August 8th, 2007, 11:34 PM   #12
perty bad
Thats how my car was when i got it
Old August 9th, 2007, 12:10 AM   #13
TurboLX's Avatar
wow dude thats pretty bad,
here's a nice HP trick for ya
first what you need is a timing light
then start your car and unplug the spout, make sure the distributor is loose so you can turn it
put the light on the crank pulley and look for the notch, turn the distributor till it's about 10* advanced, then out the spout back in and it should be around 20* advanced, tighten the distributor back down again and you made about 4-5hp with advancing the timing like that
Old August 9th, 2007, 01:02 AM   #14
well, we took out one of the spark plugs and cranked the engine over... no fuel whatsoever
Old August 9th, 2007, 01:08 AM   #15
TurboLX's Avatar
so up, bad injectors
Threads Similar to: '91 hatch wont run, please help
86 t-top hatch, hopper 5.0 Mustangs 6 October 25th, 2007 02:38 PM
hatch Iownastang 5.0 Mustangs 20 October 2nd, 2007 06:43 PM
Rear hatch wont open Kingcater 5.0 Mustangs 13 January 5th, 2007 07:18 PM
