1988 Mustang LX 2.3T
piss poor gas mileage
So ya filled up today with only 165 mile on a 15 gallon tank and it took 9.5gallons to fill up aka 17mpg..... Great 4 banger engine and i'm gettin a v6's gas milage..... so what gives any suggestions on what my problem is this time? My brain is telling me it could be the o2 sensor since that is what sends a signal to the computer to tell it to richen or lean the motor. None the less i think the exhaust might have smoked the wires causing no signal from the o2 to be read there for the computer thinks the car is way to lean and making the fuel injectors just dump gas into the engine to try and get it to not act leaned out. Any other thoughts and suggestions will be nice. Wanna get this tackled asap. Another thing that makes me thing there is something wrong with the o2 sensor and or wires is the fact the car doesn't have as much pep in its step as it used to. None the less thoughts or suggestions what my problem could be.
how's the oil consumption?
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
1988 Mustang LX Turbo
well i would scan for codes and see what the EEC say's
or maybe it's the cam
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#4 | |
#5 | |
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
#7 | |
You need aftermarket gauges then
if oil is spitting out of the breather, its because the crank case is not vented, you need that thing that hooks up to your intake so it sucks the vapors thru the intake
#9 | |
This is how it should be if the valve cover is still stock
air goes in the rebreather and suck thru a hose connected to the throttle body sense your gauges have no lites, your better off getting aftermarket gauges to moniter everything Correctly
![]() something like this? Ya thats how its set on my engine right now, i'll get a pic of all the oil all over the place tomorrow. As for the gauges I've got an aftermarket oil pressure and temp gauge. Other than that I didn't think I really needed anything else. Also what I ment is everything works fine. The tach, speedo, voltage, and such. Minus the oil pressure, engine temp, and how much gas is in the car. Whats not there is the check engine light and such. They are on the lower right hand of the steering wheel in the framing of the cluster with the speedo and such. I'll take pics of this tomorrow also for you so you can get an idea. |
where that breather is, thats where the hose is suppose to be, that oil cap sucks in the air needed, but replace it with a breather, ill get a pic of how mine was
#13 | |
PM me if you want me to make you a sig
Oh 'realy
how?
f*ck EFI
![]() and so hes got a cam? Damn I need a cam. A real cam... not a f*ckin ranger cam
Well yeah I know that now... (sleeper was tellin me that a roller automaticaly bumps me to 105hp
)EFI is better (I am bleeping it cause I dont wanna get banned and this is someone elses thread)
Threads Similar to: piss poor gas mileage
| My poor, poor engine... | throwedoff | 99-04 | 23 | October 14th, 2007 01:06 PM |
| Piss off! | homebrewed | The Clubhouse | 7 | October 11th, 2007 12:26 PM |
| I'M ABOUT TO PISS SOME PEOPLE OFF ! ! ! ! | baine21225 | 5.0 Mustangs | 29 | September 28th, 2007 07:57 AM |
| Piss test | smoke-em | The Clubhouse | 9 | August 23rd, 2007 01:12 AM |
| beating the piss out of a hertz | flattusmaximus78 | Videos | 7 | August 13th, 2007 02:47 PM |
