Discussing 334 Factory Code in the 2.3 Mustangs Forum. I gave a 334 code on my scanner from my '94 dual plug 2.3 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
334 Factory Code
I gave a 334 code on my scanner from my '94 dual plug 2.3 that I can't clear.
Check engine light is on constantly and steady. Water gauge never reads over 1/4 of the way up, either. Engine heats up fine nut never overheats, even wit this summer's heat. Any help anyone......ed |
1990 Mustang LX Turbo
9.71@141.6 mph
Well first off what type of car??
#3 | |
Re: 334 Factory Code
#4 | ||
now, turbo, there is someone wit a slower car on here
[COLOR="Red"][B][SIZE="4"]Members Against Mods Crew member #7[/SIZE][/B][/COLOR] [SIGPIC][/SIGPIC] [SIZE="5"][COLOR="Red"]Dean MSO[/COLOR][/SIZE] |
Guys, I still need ideas on a fix for the car. I already replaced the ECTS valve on the fire wall and it doesn't overheat or lose coolant...(And besides other than puttin' in a V-8!) (I already have an 87 LX w/302, massaged 4bbl ......C-4 auto in this one...)
9.71@141.6 mph
is the 2.3 stock or modded?
what plugs are you using? does it mis fire? |
The engine is completely stock, with stock plugs. It skips once in a great while and maybe that's where the lack if performance comes from. It just seems to take soooo long to get to highway speed if you're getting on a ramp.
My main concern is the ECM Code and how to fix it. As I've said I've changed the ECTS valve on the firewall and the temp gauge never goes above 1/4 (factory dash unit). But it never seems to overheat even this summer! |
9.71@141.6 mph
the slow rate of speed is normal, my brother has a 2.3 just like yours
how does it idle? |
It idles pretty good and seems to run out well. My main concern is the Check Engine Light and the 334 Code. I have changed the ECTS sensor and about to change the engine temp sensor but if that doesn't clear the Check Engine Light I'm still stuck......
9.71@141.6 mph
What else does the code say when it comes up?
im starting to think it could be the knock sensor |
The code also mentions the EGR valve. I have cleaned it out and then replaced it with a known good one and now get a 332 code, which is the EGR valve and nothing to do with the engine temp or anything else.
The car is still drivable and all but it gets to be a pain. |
block the EGR off.. you dont need it anyways
MSO that still wont clear his code if he blocked it off.
"332 EGR Valve opening not detected." how do you know it was a good one? was it new? any used parts could still give you the same problem. also maybe check to see if the EGR Valve is completly plugged in. Dunno if this is a cause.. But maybe the tube goin to the EGR valve is plugged with Carbon and not allowing and exhaust reach the vavle? |
im not saying it wud clear it, im jus sayin block it and it will give you the code anyways so who cares
blockign doesnt give you a code.. mine is blocked right
now and no codes at all. But Turbo was goin somewhere. I was recently having a misfire as well and it ended up actually being my number one plug wire. didnt misfire all the time. Was just randomly it would mis during idle more so at acceleration and driving speeds.. if you havent done a tune up in awhile would recommend it. Normally the first thing i do when i buy a vehicle. Just cause i dunno when the last time it was done so.. check the plugs as well they would be needing changing as well. |
sorry i just realized that in the topic it was 334 not 332
334 is... EVP voltage above closed limit OR EGR closed valve voltage higher then expected |
Code 334
I am intermittently getting both codes.....mainly 334 but occasionally a 332 will pop up which is a plugged EGr, correct?
possibly.. not 100% sure.. but possibly a faulty EGR Valve?
Threads Similar to: 334 Factory Code
| factory gauges? | marks87gt | Electronics | 4 | June 4th, 2007 06:50 PM |
| Factory Warranty | j3susfr3ak | 2005+ | 32 | March 8th, 2007 10:11 AM |
| Factory Upgrades | oklahomastate8 | V6 Mustangs | 2 | February 11th, 2007 09:27 PM |
| Self or Factory? | bcp5008 | V6 Mustangs | 15 | October 2nd, 2006 03:35 AM |
| factory timing? | OneBad347Stang | 5.0 Mustangs | 8 | December 14th, 2005 09:30 PM |
