why the crap cant i.............
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old August 30th, 2007, 02:21 AM   #1
92stang0802's Avatar
92stang0802 is on a distinguished road
Send a message via Yahoo to 92stang0802
why cant i burn off in my 93 2.3 lx STOCK manual trans. mustang? its like it has no acceleration. it feels real heavy. my friends mazda protega can burn off and has awesome acceleration and its a FREAKING 2.0L SADAN!!
is it because:
its to heavy should i take out the spare tire??
or WHAT ?? how can i get the thing to burn off?? and have more accel. its in perfect condition new clutch and trans. almost all the parts on that engine are new that i replaced.
i need new tires and brake pads and thats about it and the shocks need replaced to but thats IT!!
But i love my stang to death i just want it to have more power!!
Old August 30th, 2007, 02:31 AM   #2
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
you only have 105hp, and that's at the flywheel
there are a couple things you can do to get it to burn out
ranger header (or any header really, but this one is cheap)
exhaust (expensive, but it really helps)
intake (best first improvement, IMO)
you can try pullies, but they're expensive too
[SIGPIC][/SIGPIC]
Old August 30th, 2007, 02:34 AM   #3
MSO
also, your car weighs around 2800 pounds
you can also try taking weight off the front end
tubular k-member and a-arms would drop ~50pounds
taking weight off the front end helps it accelerate too.. plus has other benefits, like braking faster and using less gas (though its very expensive)
[SIGPIC][/SIGPIC]
Old August 30th, 2007, 02:39 AM   #4
so why the crap did ford make the 2.3 with 8 spark plugs and why not of made it with a 2.0? man i would hate to see a 2.0 mustangs HP if a 2.3 only has 105
Old August 30th, 2007, 02:40 AM   #5
MSO
well the 2.3 isnt designed for power
that's what the 5.0 was for
the 2.3 is for gas mileage
[SIGPIC][/SIGPIC]
Old August 30th, 2007, 02:43 AM   #6
mmm... i see ..... i see a light at the end of this tunnle.......lol
Old August 30th, 2007, 02:44 AM   #7
damn I NEED A 5.0 NOW!! (jk)
Old August 30th, 2007, 02:45 AM   #8
THANKS FOR THE INFO!
Old August 30th, 2007, 02:49 AM   #9
MSO
yea np
and 5.0 is not the answer
if you're gonna swap, you should do a 2.3T
keep all the same suspension and you'll have an engine jus as powerful
[SIGPIC][/SIGPIC]
Old August 30th, 2007, 02:53 AM   #10
KOOOL..........
Old August 30th, 2007, 04:27 PM   #11
93fourbangerstanger's Avatar
93fourbangerstanger is an unknown quantity at this point
there is always disabling your egr valve
its the cheapest mod, u can cut a piece of sheet metel to fit in between and it will block it without the check engine light coming on
check it out http://www.cadvision.com/blanchas/Ranger/egr.html
93 fourbanger /intake,exhaust,erg delete,8 inch sub...for now
fukin gas prices!
Old August 30th, 2007, 04:39 PM   #12
-cold-machine- is on a distinguished road
Send a message via MSN to -cold-machine-
done this and found that it worka nice ammount. I can now amazingly terp my tires with an auto tranny
1990 2.3L Mustang Hatchback.
2000 3.8L Mustang.
Old August 30th, 2007, 07:49 PM   #13
is there any bad things that can go wrong when i do block the valve??
Old August 30th, 2007, 08:14 PM   #14
well ive been running about a week with it blocked off and nothing yet.. I had a lil hesitation at first.. for like the first two km that i drove around. But after that. Nothing. seems to run quiter and smoother as well.. But in general if you were to give it when you first do it you should notice abit of a difference. Normally I wasnt even able to do a burn out and now I can smoke the tires with ease. I can terp the tires like previously mentioned. Just a lil while ago leaving work I smoked the tires just by holding the break giving it gas and releasing the brake once my RPM's got to about roughly 2500. still had them spinning and smoking as i left so.. But if I do encounter anything bad ill definitly be posting
2000 3.8L Mustang.
Old August 30th, 2007, 08:44 PM   #15
MSO
you mean the tire
unless you've installed a t-lok, you'd only be burning 1 tire
[SIGPIC][/SIGPIC]
Old August 31st, 2007, 01:12 AM   #16
TurboLX's Avatar
1988 Mustang LX Turbo
dude you can make anything do a burnout, just a matter of how the driver feels about doing it
brake stand it or drop the clutch
rev it up to about 6k and dump it, should start spinning
or keep your left foot on the clutch, put your heel of your right foot on the brake and use your toes and gas it up to about 5k and let the clutch out slowly and should brake stand
anything can do a burnout, we got the tires to peel on my buddies 3 cylinder geo no problem
Old August 31st, 2007, 09:29 AM   #17
Honest to god. My Lil Mustang Would not spin the tires at all. And MOS I dont have T-Lok But I had both tires spin and light up and then one stopped lol. Before if i tried doin a burn out(brake stand) either my tire would just bounce on the streetnot allowing any smoke. My brakes wouldnt hold up and id slowly creep forward.(new brake job just done not long ago. Also did the same with my 89 mustang. or My RPMS could go up and try spinning the tire but wouldnt go. and if they did go it would be like super slow. and not enough to heat up the tires to smoke
2000 3.8L Mustang.
Old August 31st, 2007, 01:00 PM   #18
MSO
(pssst its MSO not MOS)
how's that cam coming?
[SIGPIC][/SIGPIC]
Old August 31st, 2007, 01:15 PM   #19
2002 BMW 530i
don't know and don't care
Luis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the rough
Send a message via MSN to Luis_GT
Damn your teasing avatar.
OT... I thought anything that had an engine could make a burnout... like Turbo said
Old August 31st, 2007, 01:32 PM   #20
MSO
mine couldnt burn out either
i mean, i cud get the tires to chirp, but that's it
[SIGPIC][/SIGPIC]
Threads Similar to: why the crap cant i.............
Aw crap! Darwin Modular Mustangs 9 September 30th, 2007 04:02 AM
JMS products crap or what? energiesource 99-04 8 August 3rd, 2007 06:42 PM
Oh Crap WHAT DO I DO?..... 92stang0802 2.3 Mustangs 11 July 16th, 2007 09:52 AM
Is CAI crap? catchtheroadrunner 2005 - 2010 9 March 12th, 2007 06:25 PM
Well crap!!! Tony_90fox 5.0 Mustangs 5 October 7th, 2006 03:34 AM
