I need help with my fan ASAP.....
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old September 3rd, 2007, 05:38 PM   #1
92stang0802's Avatar
92stang0802 is on a distinguished road
Send a message via Yahoo to 92stang0802
a couple days ago i drove my 93 stang lx 2.3L for the day. it was geting kinda hot about in the middle or one mark above on the temp gage. didnt realy think anything of it all that day antil i noticed that the fan never turned on all that day. so today i started my stang up and i let it run for about 10 20 min. and the temp gage moved up to the middle mark and the fan was still not turning on so i fiddled with the fan wire and still no fan turning on (this is while the engine is still running). so i hopped in my car tuned on the max A/C nob just to see what would happen since i dont have an A/C pully my A/C just blows out air. and... my fan finally turned on so i left the A/C on and the engine cooled down in less than 5 minutes. than i turned off the A/C and my fan stoped along with the A/C.
What should i do? is the fan supposed to run only when the ac is on?? and what mark on the temp gage is to hot for the engine??
THANKS
Old September 3rd, 2007, 06:55 PM   #2
Top Notch's Avatar
Top Notch is on a distinguished road
I think the fans on these cars fail alot because the fan on my car did not work. The terminals on the motor were loose and when i hooked the fan straight to 12V got nothing wiggled the wire and came on briefly. Found a 2.3l stang in a junk yard and the wiring to the fan was rigged up. So im guessing they had a problem with it not coming on also. And also bought a used fan from a guy off turboford.net and it has a aftermarket motor on it. Just my 2 cent. My guess the motor is bad. Hook it up to 12V and see if it works. Wiggle the wires to see if it cuts off.
Old September 3rd, 2007, 07:10 PM   #3
i have hooked the motor up to the battery and it runs fine i have even tested the wires and i got a positive read that none of them are bad.
Old September 3rd, 2007, 07:15 PM   #4
1988 Mustang LX 2.3T
akatagyourit is on a distinguished road
I had this problem very recently with my car. If the fan is good when you directly connect it to the battery then the fan is obviously good still. You need to locate the fan controller for your mustang and replace that if you wish to use the stock fan temps. I don't remember what the turn on temp is. I'm using an aftermarket controller for my car thats set to turn it on at 182 degrees farenheit. I think the controller runs about 20-30 bucks or so. The adjustable controller is around the same price, just gonna know how to wire the aftermarket one up which isn't to hard.
Old September 3rd, 2007, 07:25 PM   #5
-cold-machine- is on a distinguished road
Send a message via MSN to -cold-machine-
i believe it somethign to do with the temp sensor same thing happened with my 89
1990 2.3L Mustang Hatchback.
2000 3.8L Mustang.
Old September 3rd, 2007, 07:56 PM   #6
sleeper_inc is on a distinguished road
Send a message via MSN to sleeper_inc
Same thing happened to me, causing my car to over heat twice and I just rigged it up to a switch and it works fine
Car: 1988 2.3 N/A Hatch w/ A4LD trans
Future Engine: 1987 Merkur 2.3 Turbo
Whats the goal? 400 HP street car that eats anything streetable and looks good doing it
Old September 3rd, 2007, 08:00 PM   #7
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
like turbo always says
get a lower thermostat
lol
[SIGPIC][/SIGPIC]
Old September 3rd, 2007, 08:57 PM   #8
that doesnt always help MSO lol trust me i went through all of this
and ended up stranded out on a highway long way from home and
no phone or money to use a nerby phone if there was any.
Thermostates only open up at a cooler temp then a normal Thermostate
would. Doesnt mean your engine will run cooler. Thus the reason for a fan. If you were constantly moving like on a long highway with no stops.
( i wasnt actually just smaller roads coming back from the beach)
you should be going at a high enough speed to have enough air going to
the rad to keep your coolant cold. without that you need the fan to help
suck that air in through the rad.
So.. check more into your wiring to check for broken wires. and check to
see if your engine temp sensor is working correctly
2000 3.8L Mustang.
Old September 3rd, 2007, 09:09 PM   #9
MSO
turbo always says the fan on these is horrible, esp wit the 2.3T
what about those flex fans or w/e, those cheap shits
i heard they work great
[SIGPIC][/SIGPIC]
Old September 3rd, 2007, 09:22 PM   #10
well i have a stock fan in mine and as soon as it kicks in my engine temp
goes down a nice chunk. they aint the greatst but they work.
If you were to buy an after market cooling fan. they are normally
designed better to increase air flow and help bring in alot more air
through the rad. Even changing the rad helps keep things cooler.
If it looks like you got the original rad in there. it could probably use a
replacement if things look Green in color. your rad isnt really
doing that great of a job aymore.. try changing to one with more rows of cooling lines. takes longer for the coolant to go through the rad completely
allowing it to cool alot more.
2000 3.8L Mustang.
Old September 3rd, 2007, 09:53 PM   #11
Normally you upgrade you're fan when you swap in the 2.3 turbo
Old September 3rd, 2007, 09:55 PM   #12
That i wouldnt know havent done a turbo setup
2000 3.8L Mustang.
Old September 3rd, 2007, 10:11 PM   #13
MSO
i was referring to the 2.3Ts that came in the car (in this case, T-bird)
[SIGPIC][/SIGPIC]
Old September 3rd, 2007, 10:12 PM   #14
ahh.. gotcha.. Was it an electric fan that was equiped on those?
or was it the actualy crank/clutch fan
2000 3.8L Mustang.
Old September 4th, 2007, 08:45 AM   #15
TurboLX's Avatar
1988 Mustang LX Turbo
Relays no good sounds like....
i put a switch and LED on it so i know when its on or off
Old September 4th, 2007, 08:56 AM   #16
The 87-88 T-birds had dual electric fans
Old September 4th, 2007, 09:45 AM   #17
TurboLX's Avatar
yes they did indeed
but good luck finding one....cheap
Old September 4th, 2007, 09:49 AM   #18
lol.
2000 3.8L Mustang.
Old September 4th, 2007, 10:29 AM   #19
MSO
i want a big fan
what do you recommend turbo? (if you ever come back..)
[SIGPIC][/SIGPIC]
Old September 4th, 2007, 10:34 AM   #20
lol get a nice heavy dut electric fan you can find em for the 5.0L lol
2000 3.8L Mustang.
Threads Similar to: I need help with my fan ASAP.....
NEED HELP ASAP!! 92stang0802 2.3 Mustangs 5 October 30th, 2007 10:04 PM
NEED HELP ASAP!!! Basics V6 Mustangs 19 October 18th, 2007 10:33 PM
NEED SUM HELP ASAP sn94 5.0 Mustangs 19 September 28th, 2007 12:34 AM
help asap please WeCircleTheProblem V6 Mustangs 14 August 16th, 2007 06:21 PM
NEED HELP ASAP!! VetteC5RFrEak 5.0 Mustangs 0 August 3rd, 2006 02:01 AM
