Speedometer
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old September 14th, 2007, 06:24 PM   #1
1988 Mustang LX 2.3T
akatagyourit is on a distinguished road
Speedometer
Well amist of doing random things to my car today I somehow broke the speedometer. Apparently when I was cleaning the cluster up today I pulled the speedometer out by the needle which caused it to come off of the actually gauge. Since then it does not work. Is there a way to fix this or do I just need to go get a new one? If a new one where can I acquire or is it a junkyard item again?
Originally Posted by Hourofpain
If i put flowmasters on my lawn mower will it sould like a gt?
Old September 14th, 2007, 06:39 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
so what actually broke?
Picture?
Old September 15th, 2007, 01:24 AM   #3
Picture?
I'll get a pic tomorrow for you. Basically you have the cluster which breaks down into seperate gauges. 1 cluster in the cluster is the amp and water temp gauge, the tach has its own cluser, the speedometer is its own then fuel and oil pressure. Well the need that connects to the motor assembly for the speedo came off. I need to know how to safely and correctly remove the speedometer motor thingy from the overlay. The new overlays I was installing do not have big enough holes to go directly over the needs so I had to pull them. I'll get a pic tomorrow my head hurts.
Threads Similar to: Speedometer
speedometer Mike73 Modular Mustangs 4 October 27th, 2007 01:49 PM
Speedometer cdesha 96-98 6 August 15th, 2007 01:11 AM
Speedometer Arhilion 96-98 8 May 23rd, 2007 07:36 AM
Speedometer. Kmh to mph Timmano V6 Mustangs 7 May 3rd, 2007 11:38 PM
Speedometer 88MustangGT 5.0 Mustangs 8 January 3rd, 2007 07:11 AM
