Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Discussing Basic help needed. in the 2.3 Mustangs Forum. Ok, here's is what I have right now: 1993 stock 2.3 with auto ...
Old November 2nd, 2007, 01:32 PM   #1
1993 Mustang LX notch
how fast can u push?
Basic help needed.
1993 stock 2.3 with auto tranny.
I bought a turbo motor from a dude. He said it is from an '86 TC, he thinks. I don't know squat about how to ID the turbo, but I do know it has the old style intake and the exhaust manifold has E3 stamped on it.
I plan on getting the block cleaned and inspected, and if necessary, .30 over. I'll look into strokin it and have the head milled, ranger cam and reworked exhaust. Also a volvo intercooler.
I also have the harness and computer from the original donor car. Since it is aparently from an older car I don't know if it will work the airbag, (which I want).
Would a computer from a known auto, (like from an '88), work the airbag?
Would there be anything that might not work with another donor computer?
Old November 2nd, 2007, 03:01 PM   #2
TurboLX's Avatar
1990 Mustang LX Turbo
8.67@165.91 mph
I dont think there ever was a TC with an air bag
the 86 engine should have a garrett T3 on it
if you do a .30" bore your gonna need new pistons, thats gonna be around $400 alone, my JE's were $450
but that ecu should work
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info
Myspace
Small Block Posse
Old November 2nd, 2007, 03:45 PM   #3
Yeah, I've seen that pistons are pretty pricey. But since time isn't a issue, I'll just save up.
Any ideas on what options I have for the airbag problem? Is re-pinning or modifying and using the stock computer an option?
How are these t3's? What can they handle?
Old November 2nd, 2007, 03:55 PM   #4
TurboLX's Avatar
8.67@165.91 mph
Most guys are re wiring it but it should be a problem with out thats for sure
the T3's only handle 300hp
Myspace
Small Block Posse
Old November 2nd, 2007, 04:00 PM   #5
"but it should be a problem with out thats for sure"
You confused me on this one.
Also, what options do I have on different turbos if I need more?
I appreciate the info and apologize for some dumb questions.
Old November 2nd, 2007, 04:04 PM   #6
TurboLX's Avatar
8.67@165.91 mph
whoops
i dont think it will give you problems if its an air bag version
all it does is just activate the sensor to tell it when to go off
Myspace
Small Block Posse
Old November 2nd, 2007, 04:05 PM   #7
TurboLX's Avatar
8.67@165.91 mph
well you can go a T3/t4 which is popular or the ever so famous HX35 and Hy35 like me and most other 2.3 guys
best turbo for the 2.3's
Myspace
Small Block Posse
Old November 2nd, 2007, 04:07 PM   #8
Is switching turbos a simple thing? Like just swap 'em out and go? (I could see maybe having to increase injector size).
Old November 2nd, 2007, 04:10 PM   #9
TurboLX's Avatar
8.67@165.91 mph
well its pretty simple if you have a basic understanding of it
but 30# injectors will be fine witha T3/T4
HX35 will need 42or better
Myspace
Small Block Posse
Old November 2nd, 2007, 04:15 PM   #10
Man, I do appreciate the info. I think I might just use an auto computer and do with out an airbag for a while. I think it would be easier to do at first. I could re-pin on another harness to hook up to the stock computer later.
Old November 2nd, 2007, 04:24 PM   #11
TurboLX's Avatar
8.67@165.91 mph
yea, the computer should work either way
unless its manual
Myspace
Small Block Posse
Threads Similar to: Basic help needed.
What're some basic things to do to prolong my engines life? Compy386 V6 Mustangs 30 January 30th, 2007 06:51 PM
Got a basic design for my tattoo. 68' GT500KR ckthecerealkiller The Clubhouse 13 January 12th, 2007 01:07 PM
Basic Information..... FunNquick 5.0 Mustangs 2 August 17th, 2006 10:08 AM
Basic 99-01 Cobra Tech FAQ 2000Si 99-04 4 September 15th, 2005 10:47 PM
