Turbo my 91 Stang?
I've been toying around with the idea of turboing my stock 91 stang.
How much boost could it handle? Would exactly would i need? Can i take a turbo from a ex.dodge diesel truck? |
find a t-bird turbo coupe and rob the head,vane,ecu,turbo,etc
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
87 Coupe
![]() iTrader: 3 reviews
you can use a turbo off a turbo diesel f250 or 2 off of any ford 2.3 turbo motors
1988 Mustang LX Turbo
The most common turbo ive seen on most 2.3 ford was a holset hx35 and is from a cummins diesel motor and which i use and run 26lbs of boost with a 30lb bov spring
and what kinda motor do you plan on doing this to?
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
91 Mustang/80 Trans Am
Heres whatch need: (If you have a 2.3litre)
Use a thunderbird turbocoupe turbo or a Garretair T3 turbo. The motor mileage has alot to do with how much boost you can handle, but if your milage is low and you take care of it, apply an external waste-gate and run up to 20-25lbs of boost. if your milage is really high, Id only run about 6lbs of boost. Even at that, a high mileage engine isnt guaranteed to last very long.
Threads Similar to: Turbo my 91 Stang?
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Looking to Twin Turbo My 83 Stang | ccstud16 | 5.0 Mustangs | 7 | December 28th, 2006 03:19 AM |
| 2000 turbo stang gt | rudedude101 | Multimedia | 0 | November 22nd, 2006 03:43 PM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
| DSM Turbo To Stang Help | GTXRacing | General Tech | 14 | July 20th, 2006 12:17 AM |
