Ok guys i got another good one...
Well The mustang was running ok except for I had no heat... so i was gonna back flush the cooling system.... bought the tee connection kit and hooked it into my inlet line... In the process of doing this the tee-connector by the outlet line broke... so i plugged off the connector and hooked straight to the heater core... flushed the system and everything ran great... good heat and all... So now i get the tee connector for my outlet line... hooked that up last night... now she doesn't shift? WTF... could I have unplugged something or does that thin line go to my transmission? I'm lost what the hell does coolant have to do with shifting... Put the car in DRIVE or Overdrive... Doesn't slip in first but won't shift to second until REDLINE.... second runs great but won't shift at all.... and when it does it will freerev then catch second again... I'm so lost... any help would be greatly appreciated... thanks guys
"Scars are like cheap tattoos they build character" "4wd is like a condom, it's better to have it and not need it then need it and not have it" 89 Mustang LX and numerous other toys |
Nevermind... Turns out I moved the Vacuum Line to the modulator and pulled it off... just a little longer vacuum line and problem solved...
Cigar Assassin
glad we could help
Threads Similar to: Ok guys i got another good one...
| One last opinion from you guys 05+ guys... | 1FastFox | 2005 - 2010 | 29 | October 8th, 2007 05:55 PM |
| Good Guys at Lethal Performance | Gunny | 2005 - 2010 | 6 | July 31st, 2007 04:39 PM |
| what websites are have good prices and good quality? | blue03mach1 | 99-04 | 5 | July 15th, 2007 04:49 PM |
| Still a few good guys out there. | 03 R Code | The Clubhouse | 14 | June 30th, 2007 06:55 PM |
| New Guy And Need Mustang Guys Advice, Come Comment Guys! | redneckstone | New Members Introductions | 11 | October 4th, 2006 07:02 PM |
