Discussing So, Here's The Plan in the 2.3 Mustangs Forum. Pics of your crank and cam pulley would help alot. The crank pulley should only ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
1988 Mustang LX 2.3T
Pics of your crank and cam pulley would help alot. The crank pulley should only have a notch on the out ring nothing special to indicate a timing mark and the cam should have an arrow of some sort with a plastic piece in the bottom right to indicate TDC on the cam. Not sure how you would have a crank pulley from another car, much less if it isn't the stock pulley then the pulley you have may be bigger or smaller than the stock pulley leading to other problems.
#22 | |
All you do is put the rotor in a position that faces #1 on the distributor cap, and leaves the ability to advance/retard the distributor body without hitting anything. The cam timing.... I used to remember how to do this on an engine missing the cam marks. Or do you have that plastic pointer on your head? reply to this please. If you're missing that pointer, there was an old way of taking a string and aligning it to your cam and aux shaft centerline. But I'd have to search for that method cause it's been a long time. The crank, If I remember correctly, all that has to be done is have the key way facing straight up for TDC. Or you can take all the plugs out of the head, insert a screw driver into the #1 plug hole and SLOWLY crank the motor by hand/ratchet/breaker-bar, till you get #1 to TDC. SLOWLY'er, turn the crank by hand and find exact TDC with the screw driver as a feeler. Someone chime in if you remember the string method! |
#23 | |
now i remember, There is an arrow on your crank's timing belt gear. Let me see if I can get a picture of that. Last edited by Mike SVOR : November 13th, 2007 at 10:30 PM. |
#24 |
go to this link http://angelfire.com/pa3/lyzcoinc/timing.html
#25 |
Thanks... The Engine Timing is right... I just did a head gasket 2 weeks ago... I'm just worried that the haynes manual says that the crank pulley notch and the timing cover mark should align during this process and they don't... so when i set the igniton timing to match that mark on the cover it's not right cuz the pulley didn't line up to start... I think i'm gonna have to take some pictures to show you guys
"Scars are like cheap tattoos they build character" "4wd is like a condom, it's better to have it and not need it then need it and not have it" 89 Mustang LX and numerous other toys |
#26 |
1989 Mustang LX
30.6@96
why would you want to remov,e the egr if you ever takew it to emissions you wont pass with out that
#27 |
IT'S TURBO TIME
1990 Mustang LX Turbo
9.71@141.6 mph
not true^
in some states all you need is a cat if its older then 1996 |
Threads Similar to: So, Here's The Plan
| new plan for the 94 cobra. | 94pacecarSVT | 94-95 | 3 | October 9th, 2007 09:57 PM |
| ok my rallying plan | Killer_Bee | V6 Mustangs | 25 | September 1st, 2007 02:59 AM |
| Exhaust plan | energiesource | 99-04 | 4 | June 27th, 2007 10:58 AM |
| The PLan | scxc15 | V6 Mustangs | 17 | March 22nd, 2007 02:39 AM |
| My New Plan | xx9gt6xx | 96-98 | 10 | November 17th, 2006 08:12 PM |
