Milling / Shaving The Head
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old November 13th, 2007, 09:13 PM   #1
hellion_79 is on a distinguished road
Send a message via Yahoo to hellion_79
How does that gain HP and how much will it add? I might be having to change the head gasket and was wondering since I have it ripped off, maybe have that done. And how much would it cost?
Thanks to everyone
PM me if you want me to make you a sig
Old November 14th, 2007, 05:17 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Head milling is a simple upgrade you can do yourself
basically your making the ports just as big as the intake and header ports so its even'd out
the mini stock guys do this and thats what gains there 400hp n/a, alot of head milling they do
i did it myself and not sure how much it will cost
Old November 14th, 2007, 11:33 PM   #3
RAMS#20's Avatar
94 Conv. GT
RAMS#20 is on a distinguished road
I usually mill my ministock heads .120. I believe you can go .150 without getting into your intake bolt holes. Most machine shops around me charge $100 for the .120 mill. It is cheap HP. This will change your cam timming so get an adjustable cam sproket to fine tune your performance.
Old November 14th, 2007, 11:55 PM   #4
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
yo rams you gotta get new pistons and such if you do that milling?
[SIGPIC][/SIGPIC]
Old November 15th, 2007, 06:59 AM   #5
So i could basically do it myself with a die grinder? I would be to afraid of going to deep and fugging up.
But what about shaving the head? I heard there is power gains through that also?
Old November 15th, 2007, 08:26 AM   #6
TurboLX's Avatar
yes you can do it with a die grinder but be careful
as for actually cutting the head, thats for fixing head warpage
but guys cut it down to make the CC's smaller for more compression
Old November 15th, 2007, 12:18 PM   #7
MSO
you can use a thinner head gasket if you want, that will increase compression
[SIGPIC][/SIGPIC]
Old November 15th, 2007, 12:39 PM   #8
93fourbangerstanger's Avatar
93fourbangerstanger is an unknown quantity at this point
what about those volvo heads
forged aluminum right?
93 fourbanger /intake,exhaust,erg delete,8 inch sub...for now
fukin gas prices!
Old November 15th, 2007, 04:31 PM   #9
TurboLX's Avatar
what about th volvo heads?
they require work to fit
ask Mike SVOR
Old November 15th, 2007, 09:09 PM   #10
More compression more power? Anyway, can I can raise my compression without tearing the motor apart?
Old November 15th, 2007, 09:33 PM   #11
TurboLX's Avatar
yes
Old November 16th, 2007, 12:28 AM   #12
RAMS#20's Avatar
94 Conv. GT
No new pistons needed, I have only had one issue with a piston hitting the valve and that is when the valve spring broke and dropped the valve. I would not go that far on old rings though.
Hellion, you can port with a die grinder just be carefull. DIY - Basic Cylinder Head Porting -Standard Abrasives Motor Sports Leave the milling to a machine shop unless you have a mill with a cutter that can cover the entire width in one pass.
Old November 17th, 2007, 01:42 AM   #13
I have nothing for machining stuff, all i have is a dremel
This summer the motor is gonna be swapped... 2.3L turbo. I was gonna swap it this winter but I am gonna get all the parts over this period of time. Cause i wanna be able to complete the swap in like a week at the longest... Cause it will be my DD.
But i was just gonna tweek on this motor a bit and see if I can squeeze a few ponies out of it. But I dont wanna spend alot of money.
Threads Similar to: Milling / Shaving The Head
CNC milling machine texas_mustang 99-04 15 June 8th, 2007 01:10 AM
friend just got a CNC milling machine texas_mustang V6 Mustangs 13 January 26th, 2007 06:59 PM
how much does it cost to install forged internals? milling? via sin dios V6 Mustangs 21 January 12th, 2007 09:46 PM
Cylinder head shaving acmillr 99-04 1 January 8th, 2007 11:34 PM
Head studs Vs Head bolts turbong 5.0 Mustangs 2 November 29th, 2006 05:28 PM
