Turbo Swap
when swapping a 88 turbo coupe motor to a 90 stang, do i need to swap computers to adapt the turbo, whats it all involved wiring wise, what do i need to add to the stock stang 4cyl wiring harness to run the turbo coupe motor.
I would use the 88 puter and get it upgraded.
john
01 Cobra Jlt Cai,BBk Lt's/cut- outs,mids/cats,magnaflows. Twin 65tb. |
Here's a good site with the info you need. Allot easier than me explaining it.
http://www.stinger-performance.com/ http://www.stinger-performance.com/turboswap2.html
Marines: Giving the enemy the opportunity to die for their cause since 1775. Guns: Giving us freedom since we learned how to shoot Mustangs: Giving gearheads a reason to exist since 1964 Turbos: Giving me a reason to appreciate all the above. |
Yes you do have to use the computer from the turbo. Also use the down spout for the exhaust, or custom make one. Make sure you save the tranny mounts and the engine mounts from the turbo coupe as well, they are fluid filled and hard as hell to find. Other then that most of the swap is pretty simple. I did this swap on a 86 capri, without fuel injection, so I had alot of wiring to do.
A hint,,,buy an air fuel ratio gauge, and an adjustable fuel presure regulator, and use an air bypass valve from a turbo SAAB, they fit right in. Also for a couple extra ponies for cheap, use a head off of a older 2.3 ranger, they had roller cams in them. |
Threads Similar to: Turbo Swap
| 2.3 Turbo Swap Overview | TurboLX | 2.3 Mustangs | 55 | March 26th, 2011 12:30 PM |
| New tach needed after turbo swap? | hooligan | 2.3 Mustangs | 2 | October 16th, 2007 05:08 PM |
| 2.3 I4 Turbo Swap over view | TurboLX | General Tech | 0 | May 1st, 2007 08:10 PM |
| no v8 swap :( !!!!!! turbo is an option, help me out | via sin dios | V6 Mustangs | 29 | December 15th, 2006 12:47 AM |
| Engine Swap 4cly to a 390 VGT Turbo | JBomb284435 | 5.0 Mustangs | 1 | September 20th, 2006 02:02 AM |
