Ranger rotors? 5-lug swap on 4cly mustang
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (6) Thread Tools
Old January 14th, 2008, 05:59 PM   6 links from elsewhere to this Post. Click to view. #1
hockey's Avatar
1990 LX 2.3 Mustang
under construction
hockey is on a distinguished road
Who has performed this ? do you use mustang bearings or the ranger ones? the dust cap don't fit ?? gee ? Also when using the ranger axles , same Question do the bearings fit or do you have to change them? I have done a little searching either i have forgot something or haven't found that either way just looking for some info. hopefully someone on here has done it before and can help THANKS
Old January 14th, 2008, 09:34 PM   #2
hockey's Avatar
1990 LX 2.3 Mustang
under construction
ranger bearings are too small! guess the mustang ones will have to do . they are just a little tight. Appreciate all the help!!!
Old January 14th, 2008, 09:50 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The only difference in the bearings is the inside diameter I believe. For a 4 cylinder Mustang you will need rotors from a 4 cylinder 83-92 Ranger and use the Mustang bearings. If they are tight they are either wrong or have too much preload on them from the nut. Fix the problem or you will be sorry. The front rotors, bearings and related parts take more stress than any other part of the car. It doesn't take much time to double check the part numbers on the bearings.
As far as axles go, the bearings are the same. Two driver side 83-92 4 cylinder Ranger/Bronco II or two passenger side 86-97 Aerostar axles and drums are what you need. 7.5 or 8.8 doesn't matter, the axle shafts are the same in both rear ends.
Old January 14th, 2008, 10:03 PM   #4
hockey's Avatar
1990 LX 2.3 Mustang
under construction
Well not tight as in preload . just the cotter pin is hard to get in ??????? The rotor turns freely after tightening the nut . the cotter pin is just a tight squeeze.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/50810-ranger-rotors-5-lug-swap-4cly-mustang.html
EASIEST 4 to 5 lug CONVERSION. Only need rotors from This thread Refback March 23rd, 2012 06:52 PM
Ford 2.3 Forums - Few shots of my 88 : Members Rides - Page 2 This thread Refback March 2nd, 2010 07:08 PM
Ford 2.3 Forums - Few shots of my 88 : Members Rides - Page 2 This thread Refback March 1st, 2010 05:49 PM
EASIEST 4 to 5 lug CONVERSION. Only need rotors from - Fox T-Bird/Cougar Forums This thread Refback February 16th, 2010 12:25 AM
EASIEST 4 to 5 lug CONVERSION. Only need rotors from - Fox T-Bird/Cougar Forums This thread Refback February 16th, 2010 12:16 AM
EASIEST 4 to 5 lug CONVERSION. Only need rotors from - Fox T-Bird/Cougar Forums This thread Refback February 16th, 2010 12:14 AM
Threads Similar to: Ranger rotors? 5-lug swap on 4cly mustang
67 Mustang Meet 460 BB Help With Swap suburban_concepts Classic Mustangs 9 November 30th, 2007 11:47 AM
Swap engine from 82 mustang into 95 mustang dreamr 5.0 Mustangs 33 November 1st, 2007 10:46 PM
ranger axles 95 mustang rotors and calipers 86ttops 5.0 Mustangs 0 August 30th, 2007 08:16 PM
Engine Swap 4cly to a 390 VGT Turbo JBomb284435 5.0 Mustangs 1 September 20th, 2006 02:02 AM
