Discussing cyl number 1 missing in the 2.3 Mustangs Forum. ok i ran out of gas on the side of the highway one night got ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
cyl number 1 missing |
mmm.. had a similar prob with my 89 I had awhile back. Everything was replaced spark plugs, wires, cap and router, filter the fuel lines,compression was good. Injectors were brand new. Nothing was wrong with it. But my fuel pump. Mine was worse then yours .. but number 1 cyl was the one that kept missing, but it would get really bad and eventually all cylinders would go one by one.. eventually car wouldnt run unless i let it sit and cool down for abit. But ended up goin away after I replaced my fuel pump.. So.. Might be worth something to check out.
well it not the Distributor cap and i cant see it being the fuel pump either the spark plug is just getting fuel all over it so could it be a broke value spring? idk im just guessing right now this car seem to do this alot to me=(
fuel pump could end up startin to lose the pressure it gives off not supplying enough fuel. Cyl1 furtherest from the pump would be deprived of more fuel. What happen to me atleast
you could have got trash in the injector screen
EVERYONE IS ENTITLED TO MY OPINION ![]() v-6's are for kids*L* clubs are ghey F/S new ford cobra intake F/S new trick flow street heat intake |
ok but when i pulled the injectors off and ran them they all sparyed the same it looked like then i put the motor back togather and did a fuel pressure test it getting good pressure even on trottle how could it drop on the just that cyl and you not notice it? i mean the spark plug is wet with gas when i pull it out after running it idk what going on this car got me so confused!!!!!!!!!!!!!!
anyone have a guess or something i just did a compression test today all got about the same soo yea=/ i still dk what to do now... i cant figure out why it not firing!!!
93 LX
set it on fire?
after you ran out of gas, did you make sure you didn't pop any seals in the fi? My bf was driving my stang one day, ran out of gas, and popped one or two of the seals... so he had to fix them in a parking lot. ran fine after that. |
1986 Mustang GT
Location: FOUND BWAL! hes now giving hand jobs to all paser bys
Ignition module? or Coil pack?
93 LX
+1 on the ignition module, didn't think of that...
I know when mine went bad the tach went nuts, it would drive fine for a little while and then start missing, backfiring, etc.. |
your engine is blown up! i think your tail light fluid is running low. maybe change the bulb. Try to dump salt in your gas tank that helps it idle better. I tried it and its cool!!!
shouldnt dump anything other then fuel, octane boost or fuel injector cleaning shit in there
no no no i think it my blinker fluid causing the problem let me go and change that damn i just didnt think of it at the time and i tore my car apart for nothing dang!
1988 Mustang LX coupe
ok, this sounds elementary, but I experienced similar prob...checked everything. Had new plugs, cap, rotor, just replaced timing belt...everything. Anyways, I eventually swapped the plug from cyl. 1 and cyl. 2, end result...cyl. 2 missed-solution....more new plugs, now it runs perfect. So try swapping 2 plugs and see if your miss changes cylinders.
Threads Similar to: cyl number 1 missing
| Most HP from 4 cyl | Brenda | 2.3 Mustangs | 64 | November 11th, 2007 08:46 AM |
| 97 V6 missing on cyl 4,5,and 6 | a_calm_victim | V6 Mustangs | 10 | July 5th, 2007 07:48 AM |
| 4 cyl maf sensor or 8 cyl? | Darrellx14 | 5.0 Mustangs | 12 | January 11th, 2007 10:15 AM |
| PCM Number? | energiesource | 99-04 | 2 | October 13th, 2006 01:39 PM |
| Looking for someone who has actually done a 4 cyl-8 cyl swap | OTreborO | 5.0 Mustangs | 0 | August 17th, 2006 11:16 AM |
