Discussing My 93 LX pings bad... wtf? in the 2.3 Mustangs Forum. hello, im new to MM. i found this site by looking for some help with ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
My 93 LX pings bad... wtf? |
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
Welcome to the forums.
check your timing.
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
with a timing gun or manually?
19.83 @ 12mph
a timing gun would be better than the human eye.
will my haines manual tell what wire to put it on? its got 8 wires on a 4 cylinder.... plz have patients with me. ive only had my stang for about 3 months. i have a bunch of hondas, tho. id eventually like to svo my stang, so i could have the best of both worlds.
19.83 @ 12mph
^ I would wait on TurboLX to answer that honestly.. I'm more of a v8 guy..
he should be here shortly.
thank you, imma check my haines manual in the mean time.
IT'S TURBO TIME
1990 Mustang LX Turbo
You have the DIZZY system which means you can not adjust the timing unless you move the crank sensor which is not worth it.
And if your pinging on a complete stock 2.3L you problably have long plugs meaning the pistons problably hit the bottom of the plugs, 93 also makes run like shit, if you go with 87 it will burn more effieciently and create more power in that 2.3 Get a set of STOCK Motorcraft plugs for it, there porven the best plugs for the 2.3's
Put up, Shut up, Line Up And Get Beat Up!!! |
thanks, i'll try the motorcraft plugs. someone told me that my timing belt could be off by a tooth. if it was hitting the plugs i think it would make noise all the time, right? its the DIS system with 8 plugs.
IT'S TURBO TIME
that could be it to, your cam could be advenced a little
Threads Similar to: My 93 LX pings bad... wtf?
| IAC BAD??? OR throttle body bad? | Rico-mofos | 99-04 | 10 | March 12th, 2008 06:32 PM |
| Bad Wheelie Gone Bad... | CAMN89GT | The Clubhouse | 7 | November 16th, 2007 07:37 AM |
| Bad Bad Bad situation | mustangmanic | The Clubhouse | 32 | October 26th, 2007 10:55 PM |
| WTF! | BWAL09 | The Clubhouse | 23 | July 12th, 2007 03:19 AM |
| bad bad wreck | 232stang | The Clubhouse | 12 | April 8th, 2007 12:37 PM |
