2.3t -> 89 Ranger
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 30th, 2008, 09:50 PM   #1
1998 Cobra
13.24@105.66
2.3t -> 89 Ranger
I have a little side project alot of you guys may think is cool.
I have an 89 ranger 5 speed, 2.3, short bed 2wd. The stock 2.3 is just out of juice.
So we have a full 87 turbo coupe drivetrain to put in it.
Has anyone ever done this swap? any modifications needed to be done to the harness?
should be fun
weeee foooord!
Old October 30th, 2008, 10:14 PM   #2
Turbo RANGER's Avatar
1990 Ranger Custom
11.60@116.19
Turbo RANGER is on a distinguished road
I have done that swap. i put a 88 turbo coupe motor in 90 ranger 2wd 5spd shrt bed. this is the same swap. you need to do some minor harness mods and repin the processor. if your truck has a map sensor, use those wires to run the VAM and pin them right at the processor. Also most modifications just need to be repinned. Get the wireing diagrams for both vehicles and go from there. It is a super fun little set up.
Old October 30th, 2008, 10:52 PM   #3
1998 Cobra
13.24@105.66
i do have the harness off the thunderbird, could I use that and make it simpler?
weeee foooord!
Old October 31st, 2008, 05:12 AM   #4
TheDarkness03's Avatar
2003 SVT Cobra
TheDarkness03 is on a distinguished road
Send a message via AIM to TheDarkness03
i wanna do this so bad. i have a 94 ranger with a 2.3 and a 5 speed, i just wouldn't know where to begin
2003 DSG COBRA COUPE
UPR CAI, Billetflow 2.76 upper w/ idlers, NGK TR6 IX's, Bassani catted X, Bassani catback, LFP Dual Pass H/E, MGW shifter, SCT X3, tuned by Greg@RET
Old October 31st, 2008, 07:16 AM   #5
TurboLX's Avatar
1988 Mustang LX Turbo
It would be easier to swap the 88 turbo coupe harness because it would be easier to swap it instead of re-pinning the stock harness to accept the LA3 ecu
Old October 31st, 2008, 07:28 AM   #6
1990 Ranger Custom
11.60@116.19
well you could go that way, but it isn't hard to repin a computer plug. You just remove it from the computer, take off the black cover on the back, depress the pin from the front and pull the wire out the back. just be sure that it latches securely when you put it back in. If you swap out the whole harness, you have to re-run it all through the firewall and around under the dash.
Old October 31st, 2008, 07:54 AM   #7
TurboLX's Avatar
Yea but the only problem with doing that is you dont know which wires go where...
IMHO its easier to swap the whole harness that way you know you didnt screw anything up while re-pinning.
Old October 31st, 2008, 12:52 PM   #8
1998 Cobra
13.24@105.66
so if i have the harness, it's literally a whole bolt in deal? Where would the ecu get power from and ect?
I put an rb20 in my 240sx and that wiring was a pain but i managed that somehow lol
weeee foooord!
Old October 31st, 2008, 01:46 PM   #9
TurboLX's Avatar
it all swaps right in
Old November 2nd, 2008, 02:25 PM   #10
1998 Cobra
13.24@105.66
hell yeah. I looked at the harness briefly today and saw a 4 wire relay and a few 3 prong connectors..
looks fairly simple.
weeee foooord!
Old November 2nd, 2008, 02:50 PM   #11
TurboLX's Avatar
it is, believe me, it's just time consuming getting it out
Old November 2nd, 2008, 10:05 PM   #12
1998 Cobra
13.24@105.66
time is no biggy. In my nissan it took a while, patience is key
weeee foooord!
Threads Similar to: 2.3t -> 89 Ranger
91 ranger 40thmustanggt All Other Vehicles 0 January 3rd, 2008 10:06 PM
Ranger Header DONE! -cold-machine- 2.3 Mustangs 115 November 13th, 2007 06:25 AM
91 Ranger Please HELP! 40thmustanggt All Other Vehicles 13 November 11th, 2007 09:16 PM
need help 91 ranger 40thmustanggt All Other Vehicles 1 August 15th, 2007 05:06 PM
The Ranger is DEAD! TheTechnical99 All Other Vehicles 5 February 6th, 2007 11:55 AM
