LinkBack (1) | Thread Tools |
#1
1990 Ranger Custom
11.60@116.19
2.3 internal buildup
Ok, decided to go with a 2.3 with an Eaton M90 sc, a Hedman hedder, and numerous other mods. Will the regular internal mods for a turbo motor work for an sc?
1990 Ranger Custom
11.60@116.19
Quick question, why does everyone hate superchargers? People act like they are the devil
1990 Ranger Custom
11.60@116.19
Also, will the stock forged pistons hold up to high boost for any period of time, or will I need to get some aftermarket pistons? On the other end, what about the mains, any problems with them?
Superchargers are where it's at Verne
1988 Mustang LX Turbo
the piston's will be fine, i've held 30psi on them for more then 15 minutes no problems.
and superchargers take power to make power 15psi on a supercharged 2.3 is gonna be less powerful as a turbocharged 2.3 at 15psi |
1990 Ranger Custom
11.60@116.19
Maybe peak HP will be higher with a turbo, but average HP will be way higher with a roots type sc. And the torque will be higher all across the board. All that aside, is there anything in the lower end besides rod bolts that needs attention?
1990 Ranger Custom
11.60@116.19
OK, so the mains are ok stock? I just don't want to have to pull this every weekend to work on it. Also, would you recomend head studs and an MLS gasket with that high of boost?
1990 Ranger Custom
11.60@116.19
Ok, that's what I've been hearing from most people. I've got a cam and valves coming, but do I need to get better valve springs with 30psi?
1990 Ranger Custom
11.60@116.19
The cam is- duration 274/ 274, Lift .500/ .500 and the valves are sealed power of the stock size. The head and intake are getting extrude honed to better the flow.
1990 Ranger Custom
11.60@116.19
HLE's?
superchargers arent that efficient on small displacement engines the only success was the early cobalt SSs if you wanna call it that.Did you come up with an 8 rib pulley setup yet?you might be better of with a 10 rib setup to reduce belt slip which could be an issue at 30 psi.Boost is boost you would basically build an engine the same way for a blower as a turbo you need enough valvespring .while your at it why dont you make it a 2.5 stroker?what year thunderbird did that blower come from?the 94 and up supercoupes came with coated rotors which are better than the earlier M90s.you could have the blower ported profesionally too to improve performance.
1990 Ranger Custom
11.60@116.19
It's a 94 blower, but i've ordered an MPx case with the MP inlet from magnum powers as well as the 10 rib 25% overdrive kit for a supercoupe because Ive already figured out how to run with a stock supercoupe pulley system
Im glad you have this stuff figured out.Keep me posted on the build up.
1990 Ranger Custom
11.60@116.19
QUOTE=Racinjason81: superchargers arent that efficient on small displacement engines the only success was the early cobalt SSs if you wanna call it that.
I got to lookin at old stuff, and BMW had roots type supercharged 500cc(30 CID) motorcycle in 1937 that made 108 hp and ran 173.3 MPH. Also, in 1951, Alf Romeo had a 1500cc(90 CID) grand prix car that made 425 bhp at 9,300 rpm. It too was roots type supercharged. I'm tellin you guys that superchargers aren't as bad as they're made out to be. Yes, I'll agree that they are less efficient than a turbo and they won't make as much peak power, but they make unflinching boost, have gobs more torque and a much better power band. Look into those old outdated and inefficient roots type superchargers and you'll find that they aren't really such a bad idea on any engine.
what i meant was recent 4 cyl roots combinations.the old outdated ones are exactly that
the newer roots type are far more efficient than the old stuff.one of my friends is making well over 1000hp with an old 6-71 on a 392 hemi obviously the old stuff works but the newer stuff makes the gap between superchargers and turbos a lot smaller
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/99780-2-3-internal-buildup.html
| 2.3 internal buildup | This thread | Refback | December 2nd, 2008 10:44 AM | |
Threads Similar to: 2.3 internal buildup
| the 2k s/c buildup..... | DeMello | 99-04 | 27 | June 22nd, 2008 11:16 PM |
| 12.6 with no power adders or internal engine modifications | gx1856 | 2005 - 2010 | 5 | May 24th, 2007 11:47 AM |
| 4v Conversion then SC or built internal 2v SC? | sorrowfulkiller | 96-98 | 10 | May 21st, 2007 01:29 AM |
| what internal components do i need? | bricky77 | 99-04 | 12 | July 3rd, 2006 09:40 PM |
| 331-stroker buildup | 173speed | 5.0 Mustangs | 10 | November 3rd, 2005 10:19 AM |
