Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005 - 2009
Discussing dyno tune & flash tune in the 2005 - 2009 Forum. why is it a good idea to get a dyno tune? (I never got one ...
Old January 7th, 2007, 10:10 AM   #1
why is it a good idea to get a dyno tune? (I never got one before) and when in my mod prosses should i get one? (mods at bottom).
also why are alot of you going with the xcal tuner instead of the predator, is there really a difference? thanks for responding.
07 gt c&l cai, predator tuner, bassani ss x pipe w/cats and axle back,and 410 gear.
my future mods are pulleys, maybe a tb spacer, springs, and wider 18's (wheels) and that should be it.
Old January 7th, 2007, 02:36 PM   #2
The main reason for a dyno tune is because having the person right there able to change parameters in a program will help achieve max power. With a dyno tune, the tuner will upload a program and run the car on the dyno, look at the results, and adjust what needs changing until you get max readings on the dyno, then flash The final program into your cars computer.
Another good thing about a dyno tune is if you go back to the same place after installing new mods they will have your old tune as a baseline and it will be easier to retune.
Or you could have some company write you tune after tune and flash them into your car but without the help of the dyno you won't really know where your improvements are and what should be changed more.
Don't think that the tunes you get sent to you are no good, they should all be tested and proven to work before the tuner sends them to you, it's just that some times the tunes are a little on the safe side since all cars will not react the same to the same tune.
Certain mods require a reflash, so your best bet is to try to do mods that you know will need a reflash before getting a dyno tune.
Old January 7th, 2007, 05:02 PM   #3
Any hole is my goal!
BWAL's Avatar
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
while we are on the subject then, do you need to buy a tuner such as an xcal 2 if you are planning on taking your car to a dyno?
1989 LX 5.0
1990 LX 5.0
1993 LX 2.3 notch
1992 LX 5.0
1997 Cobra
Buy one get one free. PM me
i founded the founder of the cobra club
Old January 7th, 2007, 07:32 PM   #4
You do not need to buy the tuner if you are going to take it and have it dyno tuned.
If you don't buy a hand held tuner you will not be able to re-flash your car back to stock prior to going into the dealership for any kind of work that requires them to run a diognostic test. From what I have been told, not 100% sure, but if they run a diognostic test and you have had your program changed it will show up as having had the battery disconnected. The diognostic computer will then set your cars program back to stock. And since you do not have the program that your tuner installed it may not run like it should. You could always go back to your tuner and ask them to re-flash for you, not sure how much they charge for that.
Also with the hand held tuner there are some options you can adjust yourself.
The Xcal will hold 3 tunes plus the origional stock tune.
Old May 31st, 2007, 04:05 AM   #5
GT/CS's Avatar
As far as I know most companies purchase the big expensive computer edit software and have this available for you to use at a greatly discounted price (course then they charge you hourly for the tune usually). For examlpe my friend has a transam and the program that would let him fully edit his ECU anytime is LS1 edit and runs around $1,000. It's better to dyno tune if you are going to say, do like head and cam work for sure rather than flash it as compared to just some intake and exhaust work and gear changes.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Threads Similar to: dyno tune & flash tune
dyno tune kennyGT 96-98 2 August 7th, 2007 08:21 PM
dyno tune xedubx 99-04 3 July 15th, 2007 11:16 PM
Dyno Tune shadow98gt 96-98 2 June 15th, 2007 06:24 PM
Dyno Tune? justinsstang V6 Mustangs 26 February 26th, 2007 10:49 PM
Dyno Tune miafan 2005 - 2009 6 January 22nd, 2007 04:45 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
