Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005 - 2009
Discussing flow chart in the 2005 - 2009 Forum. Can someone who understands this analyse this compared to a stage 2 head from livernois? ...
Old May 15th, 2009, 03:04 PM   #1
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
flow chart
This is for the heads they are sending me.
Thanks,
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old May 15th, 2009, 03:05 PM   #2
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Whats the max lift of the cams your going to be running? At .600 lift the heads will flow roughly 290 CFM on the Intake side and 193 on the exhaust side. CORR CFM is corrected CFM IIRC. So figure out what your cams max lift is then look at that chart to see where your going to be.
On the left hand side the .XXX number is what the intake/exhaust ports flow at that height of lift. Port is what side. Intake or exhuast... I miss anything?
"Its the things you love that make you who you are!" "I guess that makes me large breasts...." Penny and Howard. The Big Bang Theory
Old May 15th, 2009, 03:07 PM   #3
07 STROKER's Avatar
07 Mustang GT
my cams are 127200 comp nsr's
Old May 15th, 2009, 03:08 PM   #4
07 STROKER's Avatar
07 Mustang GT
COMP CamsŪ - Cam Details
Old May 15th, 2009, 03:10 PM   #5
tribaltek's Avatar
2005 Mustang GT
13.02@107
You're building a whole damn engine and going with NSR's?
'05 GT, 5spd, Black, JLT, 4.10, FRPP Hot Rod Cams, UDP, MGW, OBX LT & O/R-H, Bassani Race
Cammed Crew #1
Old May 15th, 2009, 03:11 PM   #6
07 STROKER's Avatar
07 Mustang GT
Im doing some grunt work for Rich with these cams before I upsize.
Old May 15th, 2009, 03:11 PM   #7
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
The max lift on those cam's according to Comp's website is .450. So somewhere in between the .400 and .500 lift is where your going to be flowing on that chart. So somewhere in the 270 CFM range on the intake side and 170 CFM range on the exhaust side. Roughly.
Old May 15th, 2009, 03:12 PM   #8
07 STROKER's Avatar
07 Mustang GT
sooooo.....these flow worse - as good- or better than stage 2's?
Old May 15th, 2009, 03:13 PM   #9
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Stage 2 what?
Old May 15th, 2009, 03:14 PM   #10
07 STROKER's Avatar
07 Mustang GT
livernois stage 2 heads.
Old May 15th, 2009, 03:15 PM   #11
07 STROKER's Avatar
07 Mustang GT
New - Livernois Motorsports - CNC Stage 2 Ford 4.6L 3-Valve Cylinder Heads
Old May 15th, 2009, 03:16 PM   #12
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Better. By about 7 CFM at max lift... Can't tell your what they would flow with those cams because I don't they don't have a spec sheet listed for them (Stage II heads) on the website. Just shows max numbers.
Old May 15th, 2009, 03:18 PM   #13
07 STROKER's Avatar
07 Mustang GT
how are you figureing this out?
Old May 15th, 2009, 03:22 PM   #14
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Ok.. See where it says lift? Below that is the hieght the valve is raised. .600 being the highest they tested the flow at. This is the MAX lift. Now, under CORR CFM. Under that column is the amount of CFM flowing through the port at the corresponding amount of lift. So, at .600 valve lift these heads will flow 290 CFM on the intake and 193.9 on the exhaust side.
Your cams have a max lift of .450. So, if you look where it says .400-.500 on the lift column and follow that over to the CORR CFM column you get your flow for your cams. Somewhere between .400 lift and .500 lift. That is.
Old May 15th, 2009, 03:26 PM   #15
07 STROKER's Avatar
07 Mustang GT
these heads have oversized ehaust valves, yet max lift shows less CFM than the stage 2 according to the website WTF. And thanks corn boy.
Old May 15th, 2009, 03:27 PM   #16
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Oversized vavles will not help flow. But they will help atomization on the intake side and help with valve wear on the exhaust side because the bigger they are the more heat they can hold/deal with. Didn't you mention they are stainless too? That will help a lot as well.
I'd still say those theads are better than stage II's.
No problem. Glad to help Maple Man......
Old May 15th, 2009, 03:28 PM   #17
2007 GT
uploading a pic for stage 2 and 3 right now. I have been looking at it. Like towelly said, they flow better at most lower lifts up to 500. 600 lift flow is of little concern. Even stage III spr blower cams dont have a .600 lift.
We are going to do some custom cams for ken down the road to match these heads.
Old May 15th, 2009, 03:29 PM   #18
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Cool. When you get some custom cams in there, they will for sure be better than stage II's.
Old May 15th, 2009, 03:31 PM   #19
07 STROKER's Avatar
07 Mustang GT
its a short road as well
Goddman UPS...Heads are 4 hours away from me sitting in Calgary and they missed the truck up to whitecourt (where I am) now they wont move untill tuesday.
Old May 15th, 2009, 03:32 PM   #20
Wherever you go!
Towelly's Avatar
2006 Mustang GT
13.04 @ 106
Shitty.
Threads Similar to: flow chart
college flow chart graystang01 The Clubhouse 7 March 30th, 2009 02:22 PM
whipple dyno chart onederful100 2005 - 2009 24 February 17th, 2008 10:45 AM
pill chart 40thmustanggt 99-04 1 January 13th, 2008 09:44 PM
New 4.10's... and conversion chart! wormster00 2005 - 2009 15 June 27th, 2007 11:40 PM
Displacement Chart StangAddiction 5.0 Mustangs 4 May 8th, 2007 10:02 AM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
