Discussing Tach Adaptor...still not working... anyone use one of these??? in the 2005 - 2009 Forum. I was told to hook it up to the green wire on the #1 coil ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2006 Satin Silver GT
11.47@118.20
Tach Adaptor...still not working... anyone use one of these???![]() I was told to hook it up to the green wire on the #1 coil and I cut the wire and connected everything as shown above... I am hoping someone has installed on of these adaptors and can tell me hoe they got it to work
![]() 2.6l KENNE BELL 100% forged bal and blu Stroked to 298 / Ported/polished heads Long tube/O/R X / McLeod twin 8 rib/65 lb injectors ET Drag Slicks/3.73 gear Detroit Truetrac GT500 twin fuel CDC AGR Spoiler D/S rotors / MGW Short Throw |
May 08 ROTM
2007 Mustang GT
slow
When you say you cut it, you spliced your tach lead and the two ends of the green you cut back together correct?
autometer wants you to wire into
the positive side of the C.O.P that would be the RED wire. make sure you disconnect your NEG battery terminal, before splicing into the C.O.P wiring
2006 Mustang GT Whipple HO FRPP Hot Rod Cams |
11.47@118.20
Emay.... that was the problem... there are two leads from the adaptor and the red one goes to the ignition side and the red/green to the coil...I just put the wire back together for tonight...
I will try the red wire tomorrow
ok cool, let us know how it
turns out
11.47@118.20
tried the red and still no go....
May 08 ROTM
2007 Mustang GT
slow
Let's go over what you have:
MM's resident Juice head
07 Mustang GT
Which adaport is is cuz I wirered up my autometer tach adapter and I had to pull my fuse block and splice two red wires together.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
MM's Mad Scientist
F-16 Killer
Tire Burn @ Warp Speed
This will work....
Tachometer Signal Wire Installation for 4.6 engine(s) Important! Disconnect one of the battery terminals before starting this procedure! Remove the lid off of the power distribution box, located in the front passenger side corner of the engine bay. Remove the thick power wire from the power distribution box, using a 10mm socket. Using the release tabs at the front and rear of the power distribution box, you can simply lift the box up (when releasing those plastic tabs at the front and rear of the box). The green covered harness connector is the last connector towards the rear of the box. To remove this connector to make it easy to work with, use a 7mm socket and unthread the last bolt inside the top of the power distribution. The bolt will not come out, but will release the connector. Remove the green plastic cover, simply by unsnapping the locking tabs. You are looking for the twin red wires coming from port C5. The individual ports are not individually numbered. The letters are cast into the bottom facing edge of the white plastic connector, and the numbers are also cast into the bottom edge of the white plastic connector, going long-ways. These are hard to see, but they are there. Cut the twin red wires about 1 or 2 inches down from the connector. Twist the cut ends from the connector side together and connect to the solid red of the Auto Meter 9117 tachometer adapter. Twist the cut ends at the harness side together, and connect to the red/green of the Auto Meter 9117 tachometer adapter. Carefully route your new adapter wires and mount your 9117 adapter. Re-assemble in the reverse order. Be careful not to pinch your new adapter wires during re-assembly
07 Mustang GT
07 Mustang GT
cliky on this bro!!!^^^
07 Mustang GT
HA ha AC...I brought pictures LOL
MM's Mad Scientist
F-16 Killer
If you connect the tach adapter to the power wire going to one cylinder, the adapter will will only count 12.5% of the power pulses in the total system. The adapter must be able to count a 8 pulses in a cycle to get an accurate reading. However, if whatever you are feeding the signal has a setting for 1 count = 1 revolution, you can wire it up to one coil pack. Most tachs and two step boxes need to see 8 (or six/four for different engines) counts to count 1 revolution though.
11.47@118.20
I'm going back in..... the strip doesn't open for two hours... thanx
11.47@118.20
I thank one and all for the help.... that wasn't sooooo bad... now I just need to git to the track and try it out.....I really can turn a wrench and splice a wire...really
07 Mustang GT
did the pics help?
MM's Mad Scientist
F-16 Killer
07 Mustang GT
im sure it was bro....*sulks*
MM's Mad Scientist
F-16 Killer
07 Mustang GT
LOL
Threads Similar to: Tach Adaptor...still not working... anyone use one of these???
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 18th, 2008 11:35 PM |
| iPod adaptor for a 99-04. | Dansby | Other Stuff | 6 | March 29th, 2008 05:28 PM |
| Tach Adaptor Needed or Not? | GTPONY1 | 2005 - 2009 | 4 | January 24th, 2008 12:25 AM |
| Tach Stopped Working.. 87 Mustang GT | NoRegrets | 5.0 Mustangs | 2 | September 2nd, 2007 04:28 PM |
| SVT Tach not working | usmcsawgunner | 5.0 Mustangs | 1 | May 2nd, 2007 07:43 PM |
