Discussing help rear end leaking. in the 2005 - 2009 Forum. My rear end is leaking out the driveshaft input. What seal is that and how ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
My rear end is leaking out the driveshaft input. What seal is that and how easy of a fix is it? I don't have time to do it today. So where can I fill it up to get it by until next weekend? I bought the oil I just need to know where to put it thanks.
pinion seal? sound right? I read there is also a vent that could be clogged? Any idea how long to change a pinion seal and where's this vent?
2007 Mustang GT
11.40 @ 121 mph
That seal is called a pinion seal. Its easy to replace. Behind where your drive shaft connects to that flange there is a huge nut that holds the flange on. Use an impact if you got it to take that nut off pull the flange out, you'll see how your left with that disc looking thing with a hole in it that the flange just came out of. That is the seal, ideally you'd have a pinion seal puller tool to remove it but if you dont a pry bar or anything you can slip in there with enough leverage to pull it out will work. Once you've removed that take your new one and tap it into place till it resembles how the old one was before you pulled it. Now just everse the process, just be careful when tightening that large nut back down because these cars used a crush sleeve from the factory to set the pinion gear depth so tighten it down to PFT just dont get crazy.
GT 6sp Grabber OrangeFor mods check my garage. 349 rwhp, 331 rwtrq Naturally Aspirated 445 rwhp, 495 rwtrq 100 Shot 60ft: 1.74 1/4: 12.15 @ 112.43 N/A 60ft: 1.71 11.40 @ 121.18 100 shot Nitrous |
sweet thanks. You know the torque rating is for that?
2007 Mustang GT
11.40 @ 121 mph
No sure dont sorry. I know a lot of guys on this forum who install their on Spydershaft driveshafts which require the removal of that nut. Check out Leonardracing.com. I bet it will have it listed in the install instructions for that driveshaft. I'll check too.
2007 Mustang GT
11.40 @ 121 mph
125-150 ft lbs according to that site
alright wish me luck. I'm gonna try to get it done tonight. I shouldn't have to change the bearing right?
hey is the pinion nut reverse thread?
1993 5.ohhhh
14.47 at 96 mph
Those things allways go out.
exploder top end with 12 psi of v-tech
Threads Similar to: help rear end leaking.
| Rear Quarter Leaking | SteviGX | 99-04 | 2 | November 26th, 2009 08:22 PM |
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 13 | October 20th, 2008 02:29 PM |
| what are signs of rear main seal leaking? | 91cobra5.0 | 5.0 Mustangs | 14 | March 10th, 2008 08:12 PM |
| T5 rear seal still leaking after install | 83 5.0 | 5.0 Mustangs | 6 | January 8th, 2007 09:17 PM |
| Rear Axel Leaking? | MSTGGT00 | 99-04 | 2 | November 16th, 2006 10:24 PM |
