Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 2005 - 2009
Discussing Cooling Down in the 2005 - 2009 Forum. Installed the Meziere w/p yesterday. Pretty easy install. Ran the car to 220*, shut it ...
Old September 7th, 2008, 03:28 PM   #1
scramblr's Avatar
2006 Mustang GT
11.72 w/ 1.71 60'
Cooling Down
Installed the Meziere w/p yesterday. Pretty easy install. Ran the car to 220*, shut it down and ran the pump. Took 20 minutes to get to 180*...pretty quick.
I then wired the rad fan to a switch and it runs with the key on ACC along with the Meziere and I/C pump. Again ran the car to 220* shut it down and ran the pump and fan. Took 7 minutes to get to 170*.
11.72 w/ 1.71 60'
298ci, Saleen S/C, BGG 8 Rib, Kooks, Stingers, 4.10, Spec 3+, Pro 5.0, GT500 FPs, GT500 T/B, CJ Springs, DSpecs, BMR - K-Mbr, Adj. Panhard Bar, LCAs, LCA Relo Brackets, Adj. UCA, Rear Sway, Sway Delete/Rad Support
My Gallery
Old September 7th, 2008, 03:30 PM   #2
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
a must mod for the seroius track whore...nicely done!
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old September 7th, 2008, 03:38 PM   #3
07 Grabber GT's Avatar
2007 GT
+1, nice ...
Old September 7th, 2008, 03:53 PM   #4
mustang fanatic's Avatar
1994 Mustang Cobra
Thats cool.
1994 Cobra - Bassanni Shorties, Borla Catback, JLT CAI, MSD Cap & Rotor, FRPP Spark Plug Wires
Coming soon: FRPP Aluminum Driveshaft, Aluminum Flywheel, and X-pipe
Old September 7th, 2008, 04:23 PM   #5
All sissies going to Hell!
navyman8903's Avatar
2008 BULLITT #3385
Killing with a smile
what tools did you use Cuz.. I tried to put mine in. and had a great time with the bottom bolt on the pump and the crank kept getting in the way and stuff......needless to say I aborted the mission. not something I have ever done.
BULLITT CREW FOUNDER (The real one)
Bassani Crew Member #5...HARDCORE CREW
MILITARY CREW
E-5
MA2(AW)
Originally Posted by 07 STROKER View Post
i put more effort into taking shits....that dash looks hideous.
Old September 7th, 2008, 04:34 PM   #6
scramblr's Avatar
2006 Mustang GT
11.72 w/ 1.71 60'
I was able to start the bottom bolt by hand. Then used a ball ended 6mm allen wrench to screw them all in. It took longer to take everything apart to get to the w/p than to swap them both out.
I've read than you can put some double sided tape on the head of the bolt so it sticks to the allen wrench and then guide it in. Also, no need to drain the coolant. I only lost about a quart by swapping them out real quick.
11.72 w/ 1.71 60'
My Gallery
Old September 7th, 2008, 04:50 PM   #7
2008 BULLITT #3385
you must be a god at doing that cuz mine puked every where. I didn't have a ball end t-handle I was looking for one but sears was all out. just my luck. But I might give another go, I didnt think of the double sided tape.
MILITARY CREW
E-5
MA2(AW)
Old September 8th, 2008, 10:54 AM   #8
RStrick0352's Avatar
2007 Mustang GT
11.40 @ 121 mph
I did mine the same way, except I did a 180' thermostat at the same time. I couldnt be happier.
GT 6sp Grabber Orange
For mods check my garage.
349 rwhp, 331 rwtrq Naturally Aspirated
445 rwhp, 495 rwtrq 100 Shot
60ft: 1.74
1/4: 12.15 @ 112.43 N/A
60ft: 1.71
11.40 @ 121.18 100 shot Nitrous
Old September 8th, 2008, 11:23 AM   #9
scramblr's Avatar
2006 Mustang GT
11.72 w/ 1.71 60'
Stock T-Stat is 180*...at least in the 05 and 06s.
11.72 w/ 1.71 60'
My Gallery
Old September 8th, 2008, 05:07 PM   #10
2007 Mustang GT
11.40 @ 121 mph
I guess not in the 07's, mine is significantly cooler than it was stock and its not due to the pump.
60ft: 1.74
60ft: 1.71
Old September 8th, 2008, 11:05 PM   #11
2006greyGT's Avatar
2006 Satin Silver GT
11.47@118.20
I am going to check into this while they still have my motor out of the car.... please give me some brands or links or point me in the right direction... plz
2.6l KENNE BELL 100% forged bal and blu
Stroked to 298 / Ported/polished heads
Long tube/O/R X / McLeod twin
8 rib/65 lb injectors
ET Drag Slicks/3.73 gear
Detroit Truetrac
GT500 twin fuel
CDC AGR Spoiler
D/S rotors / MGW Short Throw
Old September 8th, 2008, 11:13 PM   #12
2006greyGT's Avatar
11.47@118.20
Never mind... I looked again and saw the brand in the first post.... they are kinda proud of them aren't they.... good thing I am already blowing 13,500 on my stroker ,, whats another 500... and that they have them specifically for Kenne Bell equipped cars is a deal sealer for me...
Detroit Truetrac
GT500 twin fuel
CDC AGR Spoiler
Old September 8th, 2008, 11:16 PM   #13
scramblr's Avatar
2006 Mustang GT
11.72 w/ 1.71 60'
Hell, they can charge whatever they want, they don't have any competition right now as they are the only ones that make this part for our application. I picked mine up from Brenspeed. It was the lowest price I could find.
11.72 w/ 1.71 60'
My Gallery
Old September 8th, 2008, 11:24 PM   #14
qwik48r's Avatar
2002 SS
incredibly slow
nice.. is this a track car or dd? or 2nd vehicle.
thats awsome... wish I could stroke and spray my mustang into the 9's..... dreams....
turbocharged 2002 SS. 641rwhp @ 6700, pump gas.
qwik's build
Old September 9th, 2008, 12:22 AM   #15
2006greyGT's Avatar
11.47@118.20
it is going to be my after work and weekends/ strip car.. I think I might dwell in the mid 10s for a while... I don't know about a full cage in a vert... still looking for something I can live with...
and quik48r you have no worries because you are going GM aren't you.... or was that someone else?
Detroit Truetrac
GT500 twin fuel
CDC AGR Spoiler
Threads Similar to: Cooling Down
Cooling usafimj 2005 - 2009 4 June 25th, 2008 11:19 PM
best cooling setup? zincsvtcobra 4V / SVT 3 April 18th, 2008 09:04 AM
cooling fan help djh1286 V6 Mustangs 5 April 9th, 2008 04:41 PM
cooling question mx1089 5.0 Mustangs 5 February 3rd, 2008 11:59 PM
cooling zhunter V6 Mustangs 2 January 25th, 2006 06:18 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
