8.8" Axle Swap, Looking for Advice
Go Back   Forums at Modded Mustangs > Mustang Forums > V6 Mustangs > 2005 - 2010 V6
LinkBack (1) Thread Tools
Old October 24th, 2009, 11:34 PM   1 links from elsewhere to this Post. Click to view. #1
DC_Dave's Avatar
2006 V6 Vert 5spd Manny
DC_Dave is on a distinguished road
Talking
Hey guys, I'm new here but not new to Stangs.
I'm putting an 8.8" out of an '07 GT/CS (3k miles) into my '06 V6 manual.
I've got the Cobra pinion flange and I know how to set the pinion bearing preload (if I could only find a cheap 1/4" torque wrench!).
The 8.8 has UCAs, calipers & rotors still on it.
I'm a shadetree mechanic with power, air, and rattle gun. I have help. My question is: how long should this take?
Are the LCA & UCA the same for the V6 as the GT?
I need a new differential housing bushing, so I was thinking I'd just buy the Prothane rear control arm kit (Prothane 6-312) that includes the differential bushing and install them all.
I was thinking of throwing in a pair of KYB gas-a-justs at the same time since I'll be back there anyway.
Thoughts and comments encouraged, wise-ass comments encouraged. If you have any links to someone that's already done the swap, please feel free to share.
'06 V6 Convertible 5spd Manual
C&L Intake 93 Tune, Hurst Shifter, 8.8" t-loc 3.55
GT Sways, SMR STB
Old October 24th, 2009, 11:56 PM   #2
1rnkpny's Avatar
2007 G9 Eye Catcher
1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about
All I have at the moment is "Welcome to Modded Mustangs" DC Dave!!!
Old October 25th, 2009, 12:09 AM   #3
DC_Dave's Avatar
Thanks man. I found MM when 07StangGT (Rich) told me about it. I got my C&L from him.
GT Sways, SMR STB
Old October 25th, 2009, 02:39 AM   #4
2007 Mustang
Kuro has a spectacular aura aboutKuro has a spectacular aura about
the uca and lcas are the same. the swap is pretty simple. UCA is just a bitch to get to, thats the hardest part.
[url]www.ctxracing.com[/url]
[url]www.tandlmedia.com[/url]
[SIGPIC][/SIGPIC]
Old October 25th, 2009, 12:08 PM   #5
1rnkpny's Avatar
2007 G9 Eye Catcher
A rear diff with air tools shouldn't take any longer than 2 hrs. I'm not sure if the driveshaft flanges line up though. (If they're different GT-V6)
Old November 21st, 2009, 07:09 PM   #6
stang_nurse407 is on a distinguished road
I'm new to this forum, but use th collective a lot and here is the link to our 8.8 instal guide
8.8 Rear End Swap - The Mustang Collective Forums
Old November 22nd, 2009, 12:27 AM   #7
DC_Dave's Avatar
Thanks. Yes, I did the swap a couple weeks ago and actually used that guide a little bit.
GT Sways, SMR STB
Old November 24th, 2009, 08:59 PM   #8
xelitexjamx's Avatar
2006 mustang v6
xelitexjamx is on a distinguished road
Send a message via AIM to xelitexjamx
how much of a difference did it make?
06 v6 stang, 5-speed, pony package
Old November 24th, 2009, 10:24 PM   #9
DC_Dave's Avatar
The guide or the new rear axle?
The guide helped a little bit with torque values.
The rear end helped a lot. Now when I launch, I can get a little wheel spin and hook up instead of having one wheel go up in smoke and have to lift.
The 3.55 helped move 1-2 gears closer together. I think 3.73 would be ideal for the street, but I can drive around the 3.55. I couldnt' drive around the chasm between 1-2 with the 3.31.
GT Sways, SMR STB
Old November 25th, 2009, 11:35 PM   #10
2006 mustang v6
very nice... did you feel any difference with the control arms? would u recommend it? im saving to get a 373 take off rear end.. hopefully i can get it soon
Old November 27th, 2009, 09:03 AM   #11
DC_Dave's Avatar
Yes, the prothane bushings do make a difference, I had bad wheel hop when I spun the one wheel on wet pavement, now the wheel hop is not so bad. I did not replace the body-side UCA bushing because it would have added at least 30 minutes to the job and I was tight on time. At some point, I will probably go back in and replace that bushing.
I would recommend doing the control arm bushings, but it does make it a bigger job. Plan on an additional 1.5-2hrs for the bushings. Make sure you use plenty of bushing lube (I used the supergrease that comes with prothane bushings.
I used a torch to burn the hold bushings out of the bushing shells, but if I had it to do over again, I would use a properly sized hole saw to (I have a $5 set from harbor freight) drill out the rubber and then a properly sized steel wire wheel on the remaining rubber inside the bushing shell.
While you're saving, here's a link you might find helpful.
Car Parts - 3.73 8.8 mustang | Craigslist Search
GT Sways, SMR STB
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010-v6/141199-8-8-axle-swap-looking-advice.html
8.8 This thread Pingback October 25th, 2009 04:51 AM
Threads Similar to: 8.8" Axle Swap, Looking for Advice
255lph & 8.8 axle install advice sniperd 5.0 Mustangs 8 August 7th, 2009 02:41 PM
Axle Swap LA2003 96-98 2 January 10th, 2009 10:47 PM
8.8 Rear Axle Swap Bies08 V6 Mustangs 3 May 22nd, 2007 12:14 AM
7.5" rear axle Vendetta V6 Mustangs 15 April 23rd, 2007 01:57 AM
8.8" Rear Axle Bies08 V6 Mustangs 23 April 11th, 2007 08:41 PM
