clutch problem?
Ok i've got a 5 speed and whenever i'm out of gear and the car is rolling the car revs to about 2200 rpm and then drops to idle and then does it again and again until the car is stopped. Also I sometimes have trouble getting out of first gear. Sometimes when i go to park I'll have the clutch to the floor and in first gear and it bogs like it's going to die and one time it did die. Am i missing something?
2007 G9 Eye Catcher
It almost sounds like a hydraulic issue. The clutch doesn't seem to be releasing causing it to drag and keep the engine rotating at a higher RPM. What is your clutch fluid like? How many miles on your ride?
2006 Mustang GT
I have the same problem. Mines actually reved to 3000 a couple times. It doesnt do it everytime, just every now and then. Most of the time in the morning when its first been started, but it has happend when its been drivin for a while and is warm. My car is tuned to have the bbk throttle body, and i have the stock one on there because the bbk didnt work... I thought that was prolly the reason but now that i know someone else has the problem i am wondering what it is.
I'm not sure about the newer 6's but the older ones don't have hydraulic fluid for the clutch, just an adjustable cable. I always do the cheap little things first like cleaning sensors and see if that helps at all.
2007 G9 Eye Catcher
It is very rare to find a clutch cable on new vehicles. All new ones are hydraulic.
How do i check the hydrolic fluid?
most cars have a resevoir you can check under the hood, similar to the way you check your oil level.
2007 mustang v6
8.903 1/8 @74.96
i've had a few issues with the spec clutch set ups and when they do that it's because the pressure plat is damaged. if you get a centerforce duel friction clutch, that problem will go away.
Is it something that HAS to be done? How much would that cost to have installed?
2007 mustang v6
8.903 1/8 @74.96
the centerforce duel friction clutch runs about $350. most transmission shops charge about $400 to install it. if you pamper the car it could last you a bit longer. i was on the freeway at about 65mph when ihit third gear and then there was a loud pop and the she was down. i drove mine for about 200 miles with it making niose untill i broke it. if i were you i would get it replaced with in the next few weeks or so.
stay away from the freeway if you are having clutch troubles. That's just asking for failure.
It's been doing this for months so i dont think thats it
2007 G9 Eye Catcher
I still think it's a hydraulic issue.
I don't mean it's the freeway causing it. Just saying it's not the place you want to be when it goes out for good.
2006 Mustang GT
Mine has been doing the rev thing for a long long time so i dont think its the clutch but i may be wrong too.
2007 G9 Eye Catcher
Either that or a vacuum leak.
my car does the same thing... every once in a while the ref will stay around 2200 and it just does it randomly... im a mechanic and i have yet to figure it out.. i wonder if theres a tsb on it?
06 v6 stang, 5-speed, pony package |
Threads Similar to: clutch problem?
| Clutch Problem | HessiaN257 | Modular Mustangs | 0 | October 28th, 2009 12:01 AM |
| Clutch problem | chaosstangman | 5.0 Mustangs | 8 | July 6th, 2009 11:23 PM |
| Clutch Problem | all5.0motor | 94-95 | 5 | August 20th, 2008 02:08 PM |
| clutch problem! | saltydog_NM | 5.0 Mustangs | 7 | May 20th, 2008 04:49 PM |
| clutch problem? | blue03mach1 | 99-04 | 30 | January 18th, 2008 05:04 PM |
